Moving on to the turn signal bucket area. Notice how there is a raised ring around
the whole turn signal on this good fender that BD Stone sent me. This is what I
will try to replicate.
The bottom edge of the fender should be even with the top edge of the front valence
panel as you can see on the yellow piece that Garold Shaffer sent me.
Here is another view of the correct body line. Having screwed up both sides in this
area it makes me really sensitive to getting these things right in the future.
My plan of attack it to make this up in several pieces and then weld them all
together. I thought about making a hammer form for this but the piece is just
too curved for this to work. Spent an hour playing with various templates.
Putting in the double bend at the front.
Measured the bend carefully so that the front edge ends up in the right place
vertically and front to back.
Clamp on my trusty ruler as a reference line.
Try a test fit.
The piece needs to be curved slightly so take a few small bites with the shrinker.
I am not sure how this will turn out...
John
