Picked up the PMO spacer kit to keep the carbs a little cooler. Comes with longer studs, which you will probably need, and new 10mm/12mm metal lock nuts, which makes installation a lot easier against the tight carb bodies compared to normal 12mm lock nuts. If you have installed these, you will know what I mean.
Following a great tip from Ben (mb911) I got them from Larry at Youroil.net. I think it took less than a week for them to show up at my doorstep.
Click to view attachmentSo here is where I have been hanging out a lot lately. I find it easiest to work on the engine if I kneel in the rear trunk. You can see my feet at the bottom of the picture (I am standing for the picture).
Click to view attachmentA lot of the rear trunk sheet metal was cut away by the original builders, for cooling maybe? Or for easier access to the transmission and starter?
You can see that I have fully plumbed the fuel system, with the fuel regulator and gauge on the right side. There is a fuel return going back to the fuel cell, I am wondering if I need some kind of restrictor after the second carb to maintain some fuel pressure at the carb fuel inlet ports? I have a fuel pressure gauge on both side of the fuel pressure regulator so I should be able to see what happens with the engine running. I am using the PMO fuel blocks to make the AN connections.
On the side of the trans you can see the Rich Johnson throttle linkage, which is a nice piece that is easy to install. Still have to fiddle with all the geometry to get the linkage working nicely.
I also have the oil system fully plumbed, so I need to build enough of the electrical system to try starting this beast. I plan to test each system carefully for leaks and proper operation as I go...
John
