I have been wondering about the straightness of the chassis. In the front, the
fenders do not look quite right and one rear control arm needs 1.5 cm more shims
than the other to achieve the same camber. I wanted to check this out so I did
some measuring using advice from Rick and others.
First I got the car up on stands and leveled it as best I could. I was not worried
about leveling it along the length so much as side to side. I wanted to detect if the
car was twisted along its length. Using different thickness of plywood I was able to
compensate for the slope of my garage floor.
Click to view attachmentI leveled it across the pinch weld on top of the longs. My thought is get the middle
of the car level and see what each end does.
Click to view attachmentSorry about the poor picture quality. I feel bad for not providing better quality given
how much you all have to pay to see this.
Click to view attachmentI checked the floors from underneath using a level attached to a tram gauge. The
tram gauge has fingers on the ends that bridge the convolutions of the floor pan.
Click to view attachmentAfter checking multiple times and places I got it as level as my primitive equipment
would allow. Now I set up a laser level at the front of the car. Using shims of
different thickness paper I leveled the beam.
Click to view attachmentNow theoretically the car and the beam are level to each other. Using a square and
a ruler I checked the distance down from each front suspension bolt to the beam. I
picked this bogus ruler because the laser line showed up the best on it. It was really
hard to see on my steel rulers.
Click to view attachmentWhat I was really interested in was the difference side to side. I measured the two
front control arm bolts and the two bolts holding on the cross beam multiple times
to be sure I got a consistent reading. I found that the most any pair was off side to
side was 4 mm!!! Two pairs of bolts were within 1 mm!!
I think if my leveling efforts were really bad they would all be off left to right by a
consistent amount. Or if the car was really messed up then the measurements
would be off by more than 1 cm.
I think this means the front end is ok. Now on to check the back end.
John
