914350
Mar 22 2015, 04:00 PM
More.
914350
Mar 22 2015, 04:08 PM
I made this punch that screws into the Jig. Once the long is welded in place, with a lite tap on the suspension consol, It will leave a dimple and I will have perfect center for boring the hole that the suspension arm mounts to. I'll drill the hole once the car is on the rotisory.
gms
Mar 22 2015, 06:48 PM
looking good!
BTW the inner rocker cover you have is incorrect for an early (70-72) car
Click to view attachmentThis is the correct part
rick 918-S
Mar 22 2015, 07:30 PM
QUOTE(gms @ Mar 22 2015, 07:48 PM)
looking good!
Click to view attachmentIf you end up needing that outer panel I have the correct section. Just needs blasting
Click to view attachmentClick to view attachment
914350
Mar 22 2015, 07:56 PM
Ah Ha! I see. This part came off the 73 Donor. Thanks for catching that and letting me know. I would have probably noticed...after I welded it on.
I'll PM you about the peice/section that you have.
Thanks again.
914350
Mar 31 2015, 08:36 AM
Got the front corner clip and inner long tacked in place. I blasted then coated the areas with brush on weld through primer. As it is heated when welding, it melts and coats the weld area to protect it. All these areas will also be sprayed with a primer once the car is completed using internal frame coating spray.
914350
Mar 31 2015, 08:38 AM
More pics.
stevegm
Apr 3 2015, 03:34 PM
QUOTE(rick 918-S @ Mar 22 2015, 09:30 PM)
looking good!
So, Restoration Design only makes the inner rocker panel (left) for the late cars? Their part has the two curved bump outs:
http://www.restoration-design.com/store/product/PP301L
914350
Apr 11 2015, 10:02 PM
Some progress pics.
914350
Apr 11 2015, 10:05 PM
More pics.
914350
Apr 11 2015, 10:08 PM
More.
914350
Apr 11 2015, 10:14 PM
more.
rick 918-S
Apr 11 2015, 10:40 PM
Nice! Looks like you scored the correct outer longitudinal. Andy said you guys may have had a solution. If you still need one for you car pm me.
914350
Apr 19 2015, 06:34 PM
More progress pics.
914350
Apr 19 2015, 06:36 PM
More pics.
914350
Apr 19 2015, 06:39 PM
More pics.
914350
Apr 19 2015, 06:41 PM
More pics. Starting to look like a car.
914350
Apr 19 2015, 06:42 PM
More pics.
914350
Apr 19 2015, 06:48 PM
More.
banananose914
Apr 19 2015, 06:57 PM
QUOTE(914350 @ Apr 19 2015, 05:48 PM)
More.
banananose914
Apr 19 2015, 07:04 PM
Wow! Great, great stuff. I haven't been this happy since the day my wife left. Not really, she's still here. I can talk a big game because she's upstairs. Anyway, the gaps look bad ass. Thanks for all your attention to detail. The car has hit bottom and now she's starting to rebound. Thank you!
banananose914
Apr 19 2015, 07:11 PM
Hey, Old Yella. Thanks for the doors.
rick 918-S
Apr 19 2015, 07:15 PM
Love spot welders
914350
Apr 19 2015, 07:20 PM
QUOTE(rick 918-S @ Apr 19 2015, 06:15 PM)
Love spot welders
Yes, worth the investment. I think of all the plug welds I didn't have to grind and how fast and easy the spot welder is.
Luke M
Apr 19 2015, 07:31 PM
QUOTE(914350 @ Apr 19 2015, 06:20 PM)
Love spot welders
I need to invest in one too.. Keep up the great work.
FourBlades
Apr 19 2015, 07:44 PM
Wow, top notch work!
Spot welders...
John
rick 918-S
Apr 19 2015, 07:49 PM
QUOTE(914350 @ Apr 19 2015, 08:20 PM)
Love spot welders
Where did you get that set of wide arms? I have the same spot welder but I have two arms like your lower arm.
Socalandy
Apr 19 2015, 08:01 PM
Awesome
Brings back some memories
Socalandy
Apr 19 2015, 08:06 PM
Awesome
914350
Apr 19 2015, 08:36 PM
QUOTE(Luke M @ Apr 19 2015, 06:31 PM)
Love spot welders
Thanks Luke.
914350
Apr 19 2015, 08:38 PM
QUOTE(rick 918-S @ Apr 19 2015, 06:49 PM)
Love spot welders
These arms were with it when I bought it. I've seen used ones on ebay and craigslist. I've been looking for a longer set.
914350
Apr 19 2015, 08:41 PM
QUOTE(FourBlades @ Apr 19 2015, 06:44 PM)
Spot welders...
John
Thanks John.
sixnotfour
Apr 21 2015, 08:34 AM
QUOTE(914350 @ Apr 19 2015, 07:38 PM)
Love spot welders
http://www.millerwelds.com/pdf/spec_sheets/SW1-0.pdf
914350
May 18 2015, 07:46 PM
More progress pics.
rick 918-S
May 18 2015, 09:25 PM
QUOTE(sixnotfour @ Apr 21 2015, 09:34 AM)
Love spot welders
http://www.millerwelds.com/pdf/spec_sheets/SW1-0.pdfThanks for the link! I could use a wide set of tongs!
banananose914
May 18 2015, 09:38 PM
Hey Kent. Thanks for the great work. Hey Rick. Did you say tongs or thongs?
Larmo63
May 18 2015, 10:24 PM
So, this is Jim's car, and then you dig into your /6? Or, are you doing them both at the same time?
Cairo94507
May 19 2015, 06:54 AM
That looks very nice. Seeing how these cars go together is always interesting.
914350
May 19 2015, 07:34 AM
QUOTE(Larmo63 @ May 18 2015, 09:24 PM)
His then mine, though I am collecting and retsoring parts for mine for now. I'm anxious to start on mine.
914350
May 19 2015, 07:42 AM
This is pretty self-explanatory but this was an easy way to use tape to locate and transfer the holes into the new piece. The holes were in the outer long but covered with the sill plate (once sill plate was placed) so I used tape to map their location and pulled it back, welded then laid the tape back over to give me the location to drill the hole in the new piece.
stevegm
May 19 2015, 08:02 AM
Looks great. Excellent work.
Heeltoe914
May 20 2015, 05:47 PM
Really great work. I saw Andys car and its amazing. Best of Show was not surprising at WCR 2015. If you dont mind PM me I would love to stop in bring coffee, sweep floors, lift parts, hold parts anything to see this car in person, Really PM me I am a die hard free hand if you need... Yes I said FREE????
Luke M
Jul 12 2015, 06:39 AM
Hi Ken,
How's the work going on the 6's ?
Think it's time to give this a update
Take care,
914350
Aug 27 2015, 09:17 AM
Progress pic.
914350
Aug 27 2015, 09:18 AM
Progress pic.
914350
Aug 27 2015, 09:22 AM
Progress pic. It will be going on the rotisserie to start working on the pans etc. soon.
ndfrigi
Aug 27 2015, 10:15 AM
I'm sure Sir Jim can't wait to see his 914-6 restoration finish! Although he is driving another white 914-6 for now. Thanks for the update of the restoration Kent! And next time your own /6 will be next. But can you make another restoration thread for your car?
gms
Aug 27 2015, 10:21 AM
The car looks great Kent!
very nice work
rick 918-S
Aug 27 2015, 10:28 AM
Very nice work.
Cairo94507
Aug 27 2015, 12:13 PM
Looking very nice.
