QUOTE(Andyrew @ Aug 20 2018, 09:46 AM)
If your concern is not being able to lift it straight up you could unbolt and separate the arms from the jig on the ones that look like they will bind.
I think it looks great. Did you get any body/seam clamps? I think doing one clamp on the front of the long would be a good idea. Give you something strong to hold the front of the body with while you separate the bad pieces.
I'm not sure what you mean by seam clamps. Here is what I just purchased from Eastwood. BTW, the package of 8 is from Harbor Freight. 1/2 the price, 2x the clamps.
Click to view attachmentA mid day update. All the arms are built. I have to finish welding a couple on the front. Then shim the cross bracing where it lifted. Most are flush, but a couple I got to hot too soon and they shrunk.
I think I'm going to tac weld the cross bracing before I drill it. I can test the arms for clearance and so on, make sure they aren't in a bind.
When it's where I want it, I'll begin drilling positioning pins/mounting bolts. That will be a chore as most have to be done from the bottom. Then I might throw a couple more welds on the cross bracing. i don't intend to remove arms until I'm done with the project. Then the welds can be cut off and the positioning pins/bolts can be used to relocate for future use if need be.
Forgive my ugly welds.
It's hard to get in a good position and I always rush these things. I switched to square tubing on a couple on the back. It just made more sense.
