So I got around to splitting the case and the results aren't good. Did I mention I really dislike the way the previous owners treated this vehicle?
The source of the rust that was in the top of the oil filler has been found. I quickly put the oil filler & breather box aside when I was doing the initial teardown. I could see had some rust & oily gunk in there but I didn't dwell on it.
Click to view attachmentIf someone has one of these they would care to sell, there will be an ad going up in the classified section to replace this one. PM me if you have an extra you want to get rid of!
What I can't believe is how much more rusty garbage is down in the sump.
There is a staggering amount of rust and crap sitting on both sides of the case.
Click to view attachment\
I find it a little bit hard to believe that all of this came out of the breather box.
There are other indications that this engine was not rebuilt properly.
I found a metal shaving behind one of the cam bearings. luckily there was no way for this to get though the bearing oiling hole. But it does speak to the fact that the oil galleys probably were not cleaned properly before the rebuild.
Click to view attachmentOf course the bearings are worn from all this garbage in the oil and the crank is lightly scored. Hopefully the crank can be cleaned up with either an aggressive polishing and/or maybe a 1st size under cut. I need to measure the journals today to see where they are at.
Click to view attachmentClick to view attachmentAnd now let's move on to the truly egregious and incompetent stuff.
Front crank seal bore has witness marks in it from someone threading a fastener into it. Maybe they had no idea how to pull a crank seal?
Click to view attachmentThis case was literally covered in oil. It also tended to leak oil even when it wasn't running. As it sat on a dolly in my garage all winter, I kept wiping up weeping oil from under it. Eventually, I put a carboard box under it to catch the oil.
Now I know why. As far as I can tell there was little, if any sealant between the case halves!
Now keep in mind, someone plastered up the back side of the case with Epoxy / JB Weld type material over the cam plug and the oil galley plugs. After this find, I suspect they were trying to stop the oil leak that was actually coming from between the case halves from not having proper sealant on them.
There were also a number of other hits that the rebuilt was done on the cheap.
1) There were no vibration dampers on the six main bearing through bolts and/or any sealant under the washer heads to help bolt vibration and to help prevent leaks and weeping from these main case bolts. I'm always amused when a shade tree mechanic throws away parts. Surely they weren't serving any purpose and those stupid Germans were just putting extra parts in.
2) Numerous gaskets that looked like they were reused.
3) Lots of screwdriver marks on sealing surfaces where somebody was prying surfaces apart that shouldn't be touched by tools.
None of this appears to be un-fixable but it speaks to the horrors that you can find in an amateur engine rebuild by someone that clearly is just learning.
