Well, Labor Day weekend is here. I had big plans to get a big chunk of sheetmetal work done. Unfortunately life doesn't work that way.
My beloved Lincoln Precision TIG 225 has taken a dump.
Click to view attachmentWorse yet, depite my previous love for Lincoln Electric, I fear I'm on the verge of a bad break up.
Lincoln Customer Service / Tech Support has proven themselves to be absolutely useless over the course of this past week.
My welder is now ramping up to about 80A-100A immediately after starting the arc. Of course this blows major holes in sheetmetal. It does the same thing regarless of what Amptrol is attached to it. It appears that it is a control board issue. The replacement board is about $900. Keep in mind that is 1/3 the cost of a new machine. Several calls to local welder repair shops seem to indicate that they belive it is a board issue but of course they can't confirm that without me schlepping a ~ 400lb machine to and from thier shop.
I no longer have a utility trailer so any schelpping would involve a U-haul rental and even more wasted time.
For it's part, Lincoln Electric hides the detailed board schematics and any technical block diagrams of the board theory of operation behind their website which is only accessible if your a Lincoln Dealer or Authorized Repair Shop.
To make matters worse, the board is heavily potted on once side with the usual rubbery potting coupound.
The other side has what appears to be an epoxy dip coating.
This basically renders the board unserviceable according to a couple of the shops that I found that repair other boards for Miller, Hobart, ESAB, etc. I sort of get this from a reliability standpoint, these coatings shield the board from metallic dust and debris that could otherwise wreak havok. But come on. No once will touch the damn thing! One repair shop said they would try for $100/hr diagnostics & repair time and materials but no gurantee.
Click to view attachment So I've ordered a replacement board but ouf course it isn't here yet. In fact they haven't even charged my card yet which makes me wonder if the company I ordered it from is having trouble getting it from Lincoln Electric.
Moral of the story, my next welder will be blue instead of red.
I guess I'll switch gears and do some work on engine cases, bearing fits, etc.
