School of Hard Knocks - Lesson #7461There hasn't been a lot of exciting stuff to post. Mostly just paint work.
Here's a hard learned lesson during the install of the passenger side door sill.
The rear door gap was being controlled by the loose leading edge of the door jamb panel. Sorry no photo. Depending on where the door jamb was placed, it would deflect the gap either tighter or looser. All though my build I had counted on this flexibility to set the rear door gap.
Well, I had it all set, and had it successfully tack welded in place. All looked great. Again sorry no photos since I wasn't expecting things to go awry at that point.
So as I'm looking at the trough between the sill stamping and the door jamb transition, I thought to myself . . . . . self . . . . you should just use Braze instead of more tack welds. That would minimize the amount of body filler needed to fill and smooth that trough.
Smart huh?
Click to view attachmentUh . . . No.
Reinstall door only to find the gap had closed up
All sorts of profanity that I hope the neighbors didn't hear.
Click to view attachment Rear gap closed up.
So what happened?
In order to set the gap, the rear quarter panel was essentially pushed rearward and was under compressive force being held by the tack welds. During the process of brazing, I tried to do too much, too quickly and it softened the steel, allowing the compressive force to buckle the soft steel back to where the panel wanted to be without the internal stress. This closed the gap.
I would have been far better to place a couple more tack welds and to have used the plastic filler that I was trying to minimize. UGH!
So Now What to Do?I could have fixed this by simply cutting the door jamb, pushing it back to reset the door gap and then re-welding it slowly and carefully. Problem is that I'm now under pressure to get this chassis ready for a cross country trip on the back of a trailer. I am going to be moving soon and this needs to be able to go on a trailer for transport.
Yes, it's a lame excuse for not doing it right. My rationale is that I was eventually going to put steel flares on this car and to return the paint to Alaska Blue since I really do hate red cars. I know how to fix, it. I just need to keep forging ahead due to my move timeline.
So after multiple days of fighting with myself along the lines of "Just fix it right". "No, just get it done". "Yeah, but it would only take a day or two to fix it right". "No! I don't have the time." I finally yielded to the just get it done voice.
