File Under Two Steps Backward, One Step Forward.
First step backwards was removal of the driver side floor pan that was already puddle welded in more than a dozen spots. Removing spot welds is bad. Removing puddle welds is way worse. Not only in terms of the time it takes but also in the carnage it does to the panel. More on this later.
Fabricated the heater cable guide tubes that couldn't be fitted with the floor pan in place. Thought I had them close enough and brazed them into position.
All the aforementioned activity largely occured between 9pm and 1:30 am Tuesday night. Waking up the next morning my neck and back were so sore I took a day off to recover. Doing all this without a rotisserie is just masochism on my part. I still think I'm further ahead vs. stopping to build a rotisserie but I'm sure paying for it.
So after recovering I hit it again today.
Second step backward was having to un-braze the heater guide tubes and the throttle cable tube after finding they were sitting about 4-5mm too low preventing the floor pan from being reseated properly to the tunnel.
When I installed the tube bundle the other night, it was sitting about 4mm low in the tunnel bracket but being tired I figured there would be clearance. I thought filling the gap with braze wouldn't be an issue. I couldn't have been more wrong.
After un-brazing and then moving the bundle right into hard contact with the tunnel bracket, here is the clearance. The fuzzy grey on the bottom is the edge view of the driver floorpan. The tube in the foreground is the clutch cable tube, the one closest to the floorpan at the rear is the throttle cable tube. Just barely clears!
Tunnel lines fabricated, and brazed in proper postions.
After moving everything back to to be in hard contact with the bracket, it just barely clears with about 2mm of clearnace and the floor pan once again fits to the tunnel properly. One Step Forward.
Looking from rear:
Looking from front:
Next up repair the carnage to the floorpan perimeter where the puddle welds were removed.
Ordered new stainless brake line kit from PMB and a stainless fuel line set from Tangerine. These are getting installed prior to the floopan going back in!
