After much sweating and maybe a little swearing here is the weekend scoreboard.
Headstuds: 23 of 24 removed without lifting out the magnesium threads.
There is always that one that refuses to go along with rest.
P&C's
Yup, the 1,2,3 bank pistons also kissed the heads. I guess that makes a perfect score of all 6. At least we have consistency.
Crankshaft:
Visually looks good. only the lightest of scoring that can't be felt with a fingernail. Standard bearings in place.
Click to view attachmentCase:
With respect to the previously mentioned casting gate, the shrink is over the main webs, in a very thick section, and is indeed casting shrinkage. No chance of perforation of the case.
Initial visual upon 1st splitting the case was great.
But, then I got to bearing #7. Not good. Something went very bad. Either casting porosity, corrosion, or major fretting. I don't see any fretting on the other bearing web's. Likewise this is the only place inside the case that looks like this. I'm going to rule out corrosion as I can't see how it would be localized to just one web. That leaves casting porosity as the likely suspect.
Click to view attachmentClick to view attachmentI had planned on this being a core engine and needing machine work. Sent pictures to Ollie's today and they think all can be made well in exchange for $$. Likely to be on the order of $2600 to include potential welding, machining, line bore, adding case savers, oil bypass modification, extraction and repair of a couple transmission studs, etc. Life if good if you're Ollie!
10-12 week lead time to even get to it. Good thing I have at least a year!
Overall not a bad weekend! Beats being at work but I had to go back today to pay for this endeavor.
