Started to prepare the rear bulkhead for new sheetmetal. Started by getting new panel holes for the snorkel and the speedo cable aligned to OEM sheetmetal.
Click to view attachmentAs usual, one thing leads to another. Needed to know how that outer bulkhead would fit to the inner bulkhead. And then of course since the inner bulkhead seemed too low, I needed to know how the new floorpan would fit.
After exhausting my supply of vice grips and welding clamps I had a temporary loose mockup. Turns out it all looks to be pretty straight forward and fits pretty darn well for repop sheetmetal.
Click to view attachmentBy then it was getting late, I was delerious, and after spending so much time in the hell hole, the sprayed on truck bed liner + the contact cement adhesive was grating on me.
Based on some pin holes that are on the interior passenger side that I had found when I had to cut out to access all of this work, I had a feeling that the driver side bulkhead was probably hiding some rust. Turns out I was right. That damn OEM engine pad that holds moisture had done its work. The driver side had some pretty heavy pitting and a few pin holes too.
More metal work!
I was told this car was previously Florida car and owned by a body shop guy. I have found plenty of sand in the car so I suspect it may truly be a Florida car. Good body shop guy, well maybe not so much. Cheap body shop guy, maybe.
I had an inclination that the spray on bedliner wasn't just there for noise deadning. I hate when people just try to cover over rust and pretend it isn't there.
After many hours of listening to the flail wheel and after going though a fresh $40 belt, I got most of the bulkhead stripped. That crap is tough and doesn't come off easily. If anyone has better suggestion to stripping bed liner I'm all ears!
