QUOTE(carr914 @ Mar 25 2009, 08:51 PM)
QUOTE(Richard Casto @ Mar 25 2009, 04:48 PM)
QUOTE(carr914 @ Mar 12 2009, 08:42 PM)
Progress on the Compliance Sticker
Click to view attachmentTC,
What was your method for replicating the anti-peel circular pattern on the sticker?
Richard
5mm biopsy tool, practice and patience. Still waiting as another member is making me a jig to perforate the Vin# and birth code.
T.C.
Nice idea on the biopsy tool. I know exactly what you are taking about. I am assuming you have to be in the medial industry to get one of those? Or is there a source of these for every day people?
Regarding the punch, how is he making the jig?
I was thinking about this myself and I was wondering if you could create a template (MS Word or similar) for the characters used on the sticker (0-9, etc.). Then using those characters, create and print a dimensionally correct paper template with all of the sticker info info on it. You would then align this template over your sticker and use a custom hole punch to punch each hole one by one.
I was thinking that the custom hole punch might be created by selecting a drill bit of the correct diameter (those holes are pretty small), drill a hole in a steel plate with the bit, then sharpen flat one edge fo the bit and polish the surface of the block to complete the punch. I guess if you wanted to get really crazy, you could convert an existing hole punch with the custom bit and block.
