Subaru Engine Conversion Wiki, Let's compile all the knowledge into one thread... |
Britain Smith |
Sep 9 2010, 10:58 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Transmission Options
There are several different approaches to the transmission/CV options. Here are a couple of threads with further details: Subaru transmission installation, Now it's a reality!!! Subaru Transmission into 914, DAMN that turned out good!! Subaru Transmission successfully installed?, This awesome engine needs a Modern Transmission Axles for Subaru Conversion, 914 hubs ok? Axle questions for a Subaru Tranny, Another Subaru conversion.. - Adaptors/Flywheels/Clutch For mating with a 901 transmission, there are three options that I am aware off. 1. Kennedy Engineering (http://www.kennedyeng.com/vw_por.htm) Package consists of an adaptor plate, flywheel, and pilot bearing. - 215mm flywheel package for $540 (Clutch Package $431) - 9" flywheel package for $540 (Clutch Package $354) (Clutch Package includes Pressure Plate/Disc/Throw-out Bearing) - Flywheel weighs 19lbs. 2. OutFront Motorsports (http://www.outfrontmotorsports.com/clutch_flywheel.htm) Offer a monolithic flywheel (i.e. 1 peice) in both 8" and 9" diameters with adaptor kit for $480 Also have a 2-peice welded flywheel for $440 Multiple clutch packages ranging from $110 to $250 with a 6-puck disc for $80. Also mention a dual clutch disc set-up for a light pedal. Flywheel weights between 15lb and 16lbs (IMG:http://www.914world.com/bbs2/uploads_offsite/www.outfrontmotorsports.com-364-1284052723.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.outfrontmotorsports.com-364-1284052724.2.jpg) 3. Renegage Hybrids (http://www.renegadehybrids.com/) Don't really break down the adaptor plate seperatly on their website. Includes Billet Adapter Plate, Custom 9" Flywheel, Kevlar 9" Clutch Disc, Stage Two 9" Pressure Plate Some random images of adaptor plates, I don't know which manufactures. - CV Joints/Output Shafts There are replacement output shafts for the Subaru transmission to 914 CV joint. There are the option to machine a set of 911 axles to mate up to the stock Subaru CV joints as shown by BIGKAT_83. "The axles are 911. These are a large enough diameter to be machined on the transaxle side for a Subaru CV joint spline. This gives me a 911 large CV joint on the wheel end and the Subaru joint on the transaxle side. " (IMG:http://www.914world.com/bbs2/uploads/post-194-1283996263.jpg) - Shifters/Shift Linkage |
Lo-Fi Version | Time is now: 18th May 2024 - 01:14 PM |
