Matty900
Jul 23 2017, 12:46 AM
I realized that I had wrapped the wiring harness with the wrong width of tape. So I pulled it and redid it with the correct width.
Matty900
Jul 23 2017, 12:50 AM
Got in some new grommets for the headlight and fog light wires.
Matty900
Jul 23 2017, 12:52 AM
Got the mixing boxes installed
Matty900
Jul 23 2017, 12:55 AM
Put new seals on the long to mixing box hoses and installed them with the re plated hose clamps
Matty900
Jul 23 2017, 12:56 AM
Matty900
Jul 23 2017, 12:58 AM
Matty900
Jul 23 2017, 01:01 AM
Time to clean up the carbs
Matty900
Jul 23 2017, 01:06 AM
The tunnel is the last part of the car needing some love.
Matty900
Jul 23 2017, 01:09 AM
We pulled out the wiring harness to clean out the tunnel and sort out a few wires that had shorted and melted together.
Matty900
Jul 23 2017, 01:13 AM
One of the cleaning tools used
Matty900
Jul 23 2017, 01:15 AM
Dremel tool on a wand and lots of wire brushes helped to clean out a lot of the areas
Matty900
Jul 23 2017, 01:17 AM
As clean as I could get it.
Matty900
Jul 23 2017, 01:18 AM
Rust conversation applicator
Matty900
Jul 23 2017, 01:21 AM
Cleaned up shifter linkage from the tunnel
Matty900
Jul 23 2017, 02:15 AM
Found the other door latch to get cleaned up
Matty900
Jul 23 2017, 02:18 AM
Cleaned up the tail light housings
Matty900
Jul 23 2017, 02:20 AM
Added new seals
Matty900
Jul 23 2017, 02:22 AM
Test fitted some new taillight lenses
Matty900
Jul 23 2017, 12:00 PM
Found a very small hole through the bottom of the tunnel that needed welding. Easy fix.
Matty900
Jul 25 2017, 08:02 PM
The carbs cleaned up nicely. There a few thing's that are broken and need to be replaced.
Matty900
Jul 25 2017, 08:05 PM
Today's fun was cleaning up the wiring harness and figuring out where to start repairing it.
Matty900
Jul 25 2017, 08:09 PM
Matty900
Jul 25 2017, 08:11 PM
Everywhere the green tape is at is where a wire was melted to nearby wires.
Matty900
Jul 25 2017, 08:13 PM
This little bastard was the issue.
Matty900
Jul 25 2017, 08:20 PM
A previous owner cut the gray wire here and spliced in something. Does anyone have any ideas on This?
I have cut the wire between the fuse panel in the car and the snorkel but everything after that is encased and I am hoping not to have to cut in to it to repair things. I will be running carbs but was hoping some day to put the FI back one day.
Matty900
Aug 3 2017, 12:06 AM
Test fitting some new parts in the car.
Matty900
Aug 3 2017, 12:14 AM
Got the Eastwood treatment in the tunnel (you can kind of see the green in the tunnel in the picture above) I treated all the other surfaces inside the car that were not treated. Now waiting for it to dry completely. The high temps this week should help. I have been keeping a fan running to help the drying
Matty900
Aug 3 2017, 12:16 AM
Got some help from my big brother Mark (Mikey914)
Matty900
Aug 3 2017, 12:19 AM
Got some new 914 Rubber seals in the trunk
Matty900
Aug 3 2017, 12:22 AM
Got the new wiring harness insulating sleeves on all of the tabs now
Matty900
Aug 3 2017, 12:25 AM
Got the new vent filters in and the re plated door striker plates on the car
Matty900
Aug 3 2017, 12:32 AM
Picked up a new wiring harness in great shape to replace my melted harness. I will be working on it tomorrow but the forecast is calling for a high of 107. Hopefully I won't melt working in it.
Matty900
Aug 5 2017, 02:01 AM
Ended up pulling the entire harness out
Matty900
Aug 5 2017, 02:03 AM
Matty900
Aug 5 2017, 02:05 AM
While I'm in there
Matty900
Aug 5 2017, 02:07 AM
I will replace the dash face with new metal and vinyl.
Matty900
Aug 5 2017, 02:15 AM
Got the old harness out and compared it to the 2 I picked up hoping for a miracle. Unfortunately they did not match up but it did have the needed wires all intact.
Matty900
Aug 5 2017, 02:18 AM
tedious work but I was able to get the donor wiring harness broke down
Matty900
Aug 5 2017, 08:50 PM
Made some progress today. Went through every wire in the harness pulled the wires that I needed from the donor harness and started putting them in my harness to replace the damaged ones.
Matty900
Aug 6 2017, 01:42 AM
Engine is getting closer to being done. Now I need to figure out what transmission to use. I have the one from the 73 that I think will be the upgrade. I will be asking for advice on this swap in a separate thread.
Matty900
Aug 9 2017, 11:33 PM
Engine build is progressing along nicely. Case is now closed.
Matty900
Aug 9 2017, 11:37 PM
Scott rebuilt the steering rack for me with new bushings and bearings. We will be putting turbo tie rods on next
Matty900
Aug 9 2017, 11:41 PM
Added front sway bar with new 914Rubber sway bar bushings.
Matty900
Aug 9 2017, 11:43 PM
Cleaning up and replacing everything possible on the suspension.
Matty900
Aug 9 2017, 11:47 PM
New struts/shocks from PMB that I bought right after getting the car. Thought I was going to be driving it with just a few tune up items.
Matty900
Aug 9 2017, 11:49 PM
Had to figure out how to get the spring purch off. (Thank you Cary)
Matty900
Aug 9 2017, 11:51 PM
Cap and purch cleaned up and on the new shock
Matty900
Aug 9 2017, 11:53 PM
Rebuild steering rack back in with powder coated parts.
Matty900
Aug 10 2017, 12:02 AM
I will be upgrading to a side shift transmission. Getting the already powder coated kit from Bruce Stone.
Matty900
Aug 10 2017, 12:05 AM
Adding new 914Rubber control arm bushings.
