Matty900
Aug 22 2017, 12:24 AM
Cary was busy
Matty900
Aug 22 2017, 12:25 AM
Harvested the rear sway bar off of my 73 but now I need to track down the bolt for the suspension on the trailing arm that has the cup for the drop link before I can add the sway bar
mb911
Aug 22 2017, 07:12 AM
Matt,
Looks great . in another thread folks are looking to get rear shocks just like yours. Where did you source them?
Matty900
Aug 22 2017, 10:12 PM
QUOTE(mb911 @ Aug 22 2017, 06:12 AM)
Matt,
Eric at PMB Performance
Matty900
Aug 22 2017, 10:19 PM
Need to get the gas tank cleaned up next. The outside was painted and I thought it was treated. Looking inside, I think it needs a little more love.
Matty900
Aug 22 2017, 10:20 PM
Put some apple cider vinegar and ball bearings in the tank for the night. Worked it around inside pretty good to get every angle.
Matty900
Aug 22 2017, 10:22 PM
Sealed up so I could work the ball bearings and vinegar all around
Matty900
Aug 22 2017, 10:24 PM
Had to get a few photos of some of our new parts.
Matty900
Aug 22 2017, 10:25 PM
Matty900
Aug 22 2017, 10:27 PM
With the suspension in we could tighten the spring up front
Matty900
Aug 22 2017, 10:38 PM
Starting to look like a car again.
Matty900
Aug 22 2017, 11:13 PM
Installed new stainless steel lines in the tunnel
Matty900
Aug 22 2017, 11:14 PM
So far I've only been able to get one through the grommet. I'll continue trying tomorrow
Matty900
Aug 22 2017, 11:16 PM
Need to figure out which Tabs are used for holding the lines and place in the tunnel.
Matty900
Aug 22 2017, 11:18 PM
Got the new pedal cluster in that Bruce Stone restored for me and added a plate for hand throttle since I'll be using carbs.
Matty900
Aug 22 2017, 11:21 PM
Everything but the wiring harness and carpet is now in the rrar trunk
Matty900
Aug 22 2017, 11:23 PM
Replaced the grounding strap for the transmission.
Matty900
Aug 22 2017, 11:26 PM
Added new engine Bay liner with water proofing.
Matty900
Aug 22 2017, 11:31 PM
New Dash face metal and vinyl ready to install tomorrow.
Matty900
Aug 22 2017, 11:34 PM
Got the headlight surrounds all cleaned up. Love the look of the white on there with the red.
tygaboy
Aug 23 2017, 08:03 AM
Awesomeness!
Every time I see these restorations I get a little overwhelmed thinking about all the work ahead of me.
But as I follow along with your build, I can see that chipping away at it will get it done.
(though it's a bit unfair that you get Super In-Law help! Does he make house calls?
Thanks for the entertainment and encouragement to soldier on!
Can't wait for the post when you fire it up and do the first drive. Soon?
cary
Aug 23 2017, 08:11 AM
Looks like you were busy after we left ................
bbrock
Aug 23 2017, 08:15 AM
QUOTE(tygaboy @ Aug 23 2017, 08:03 AM)
Awesomeness!
Ditto. Your work is inspiring while also making me want to
myself a little over the amount of work ahead. Keep the posts coming!
mb911
Aug 23 2017, 08:50 AM
QUOTE(Matty900 @ Aug 22 2017, 08:12 PM)
Matt,
Looks like those are now nla.. Asked Eric today.
Matty900
Aug 23 2017, 10:16 PM
QUOTE(tygaboy @ Aug 23 2017, 07:03 AM)
Awesomeness!
Thank you sir. Your project is very inspiring. I have not done much in the fabricating side on this build but I will do an outlaw next.
Super in law is awesome! Very inspiring to work with him.
Hopefully the engine will be done next week.
Matty900
Aug 23 2017, 10:18 PM
QUOTE(cary @ Aug 23 2017, 07:11 AM)
Got more done last night than tonight. Decided to take the entire tail end of the one of the wiring harnesses that I picked up and use it to replace the damaged section on my old one.
Matty900
Aug 23 2017, 10:21 PM
QUOTE(bbrock @ Aug 23 2017, 07:15 AM)
Awesomeness!
Don't worry about the end and just enjoy the journey. I am loving just working on each detail and really learning the car and our parts.
Matty900
Aug 23 2017, 10:24 PM
QUOTE(mb911 @ Aug 23 2017, 07:50 AM)
Matt,
I bought them from him right after I bought the car thinking that I was just going to freshen it up and drive it. We will start to carry things like listen to Future once we get our website done. In the meantime we'll keep making more parts for you.
Matty900
Aug 23 2017, 10:26 PM
Continued getting the dash ready today. Put the new vinyl on the glove box door.
Matty900
Aug 23 2017, 10:27 PM
Wrapped the vinyl around the base of the door like the Factory did and clamped it to let it set up for the night
Matty900
Aug 23 2017, 10:29 PM
Cleaned up the heater control lever and got it put back together I'm ready to go in
Matty900
Aug 23 2017, 10:32 PM
Hope to get the hand throttle, heater control, linkage and wiring harness into the tunnel tomorrow.
Matty900
Aug 23 2017, 10:36 PM
Got the vent hose and the hose from the passenger side long to the mixing box installed. Had to get the mixing boxes and the interior vents screwed back in after painting the interior.
Matty900
Aug 23 2017, 10:39 PM
On the drivers side I mocked up and alternative hose that we sell too, to try and figure out what one I like better. What do you think?
Matty900
Aug 25 2017, 12:46 AM
Got the wiring harness finished today
Matty900
Aug 25 2017, 01:05 AM
Got the harness fished in to the front trunk (again)
Matty900
Aug 25 2017, 01:13 AM
Got the hand throttle figured out and will be completing the installation tomorrow.
Matty900
Aug 25 2017, 01:18 AM
Got the shifter out of the 73 to go with the hand throttle and the restored sideshift linkage that I got from Bruce stone.
Jamie
Aug 25 2017, 01:19 PM
Aside from presenting an epic rebuild, I compliment you for the excellent photography that has brought this work up close and well documented. As a retired photographer, I'm curious about the camera equipment used to make these images? You were often working in some very confined spaces!
76-914
Aug 25 2017, 04:11 PM
QUOTE(Matty900 @ Aug 23 2017, 09:39 PM)
I ike the Aeroduct. It's a better product but it isn't original in appearance like the first.
Matty900
Aug 25 2017, 10:39 PM
QUOTE(Jamie @ Aug 25 2017, 12:19 PM)
Thank you
Believe it or not, these are just on my phone. Although I did bring some lighting in because it was hard to see some of the stuff and I'm trying to take pictures of our parts and installation information to eventually make it on our website (914Rubber.con)
Matty900
Aug 25 2017, 10:43 PM
QUOTE(76-914 @ Aug 25 2017, 03:11 PM)
They are both nice, but I will be going with the Areoduct hose after I get the wiring harness back in.
Matty900
Aug 25 2017, 10:51 PM
Another long day today. We (Cary) got the the fuel pump inspection door cut out and got the panel blasted, polished and painted. I ran the wires the the harness already so now I just need to work in the ground back to the main grounding post buy the fuse box.
Matty900
Aug 25 2017, 10:55 PM
Super-in-law was busy cutting up another car, but posed for a photo. I told him we needed one for a t-shirt that we can put him in a cape. "Super-in-law... Jack of all trades"
He is my hero
Matty900
Aug 25 2017, 10:56 PM
This is the rebuilt steering rack that I neglected to get a picture of earlier
Matty900
Aug 25 2017, 11:02 PM
Got the new LED lights in and took plenty of pictures for installation instructions.
Matty900
Aug 25 2017, 11:06 PM
Got the Dremel tool with the wand out and clean the paint off of all of the ground Post terminals
Matty900
Aug 25 2017, 11:12 PM
Got the wires in to new boots for one side. What a pain in the assembly! I now understand why we started making pre-wired boots. Way easier to cut out the old dad wires and Boots and just add fresh new ones.. but after working so hard to preserve this harness I'll probably do it the hard way on the other side too.
Matty900
Aug 25 2017, 11:14 PM
Cary got these on today too
Matty900
Aug 27 2017, 01:57 AM
Got all the turn signals wired and installed with new boots and seals
