Mounted the trigger wheel and crank position sensor to get things started.
But now, off to the oil leaks.
Needless to say the valve cover gaskets were leaking.
Primary leaks are from the push rod tubes. I'll tackle the left first.
Off come the rocker arms ....................
Click to view attachmentFound a couple issues. Engine has maybe an hour of total run time.
Click to view attachmentClick to view attachmentHad trouble pulling out #2 intake tube ..............
Had the same trouble putting in the #2 intake tube. The other 3
snapped right in. Then gave them a 180 degree twist.
We'll take it back out after the right side is done.
Like I've mentioned in other threads I've always used Jake's original Permatex Teflon thread sealant with no leaks. Old school guys just use engine oil. I'm not that lucky.
And I hate the old cliche
air cooled engines are supposed to leak. So I'm trying DOW 55 seal lube.
Looks like cold cream.Going to be a very fast month. Get Matt ready for Route 66 and preparing the Rothsport rally cars for the Mexican 1000. Plus a Hummer service support truck, Dakar style this time. Leaving for Baja the morning of the 18th of April.
The race is on ....
