Series9
Jun 3 2006, 11:16 PM
next:
Series9
next:
Series9
Jun 3 2006, 11:17 PM
next:
Series9
Jun 3 2006, 11:18 PM
Next:
Series9
Jun 3 2006, 11:19 PM
We had a great night. The engine runs perfectly.
Last:
redshift
My car doesn't ruN! DON'T! DON'T MAKE IT RUN! IT WILL STOP RUNNING! YOU WILL BE SORRY IF YOU DRIVE IT!
Nice dood!
M
Series9
Jun 3 2006, 11:52 PM
Miles,
I will see you face-to-face next year...
GWN7
Jun 3 2006, 11:54 PM
when you do Joe...bring food
So.Cal.914
Jun 4 2006, 02:09 PM
I've been following your thread (Great car) and when you were getting the loom
ready you mentioned adding a few wires for your six. I am doing a ground up
resto right now on a 74 and I would like to add those wires to the loom now for
a future conversion. Could you let me know the guage, number of wires and
starting point and destination. Thanks.
Series9
Jun 4 2006, 09:28 PM
There are really only two wires that need to be added. One for the oil PSI and one for the oil temp.
Series9
Jun 5 2006, 08:13 PM
So I had to remove the alternator to fix a self-induced wiring problem.
Those of you who have done this on a six can understand what I went through today.
Series9
Jun 5 2006, 08:15 PM
Here's the optical trigger for the MSD installed under the 6A box (the wiring will be made neater once the coil mount is here):
Series9
Jun 5 2006, 08:16 PM
Carpet arrived. Thanks James.
Series9
Jun 5 2006, 08:17 PM
last
Final arrangement of the front:
Eric_Shea
Jun 5 2006, 09:17 PM
Did you take a picture of a box??? You're almost as bad as McMark!!
Aaron Cox
Jun 5 2006, 09:20 PM
joe, not trying to beat a dead horse...
but any airflow to the cooler? why there?
JoeSharp
Jun 5 2006, 10:06 PM
Aaron: the air box is gone and the grill sets in a vacume. there will be plenty of air going across it.
:PERMAGRIN: Joe
Aaron Cox
Jun 5 2006, 10:09 PM
opening in front of tub?
then i could see *some* airflow.....
just curious is all.....
JoeSharp
Jun 5 2006, 10:15 PM
I think all you would need to do is not install the gromets.
:PERMAGRIN: Joe
Brad Roberts
Jun 6 2006, 11:50 AM
OK. Now I'm curious about the "NO Airlfow" through the cooler question.
I do agree most engines used for daily driving can get away with "radiating" heat with no airflow when a cooler is added to an engine with the stock engine cooler in place.
B
Series9
Jun 6 2006, 06:20 PM
We removed the plugs from the bottom of the front trunk to promote airflow from the air inlet in front of the windshield, across the cooler and out the bottom of the trunk.
The gas tank compartment will need to be sealed to make this happen, however, this is a stock 2.7. Very minimal airflow should do the job. The cooler is very large for a 2.7.
It's experimental. Think of it as a battery warmer.
Worst case: We'll add a fan to the cooler. It'll be fine.
Series9
Jun 9 2006, 06:52 PM
Headers back from ceramic coating. They're on the car now. I'm sending the muffler to be coated too.
Series9
Jun 9 2006, 06:54 PM
Magnecor spark plug wires:
Series9
Jun 9 2006, 06:58 PM
And the carpet set out of the box (for Eric).
I spent the day installing the exhaust, tuning the engine with the Crane optical trigger (points replacement) and installing the master cylinder.
Things are going well, but I'm still behind.
morph
Jun 9 2006, 10:17 PM
this is what your after im assuming.
all the plastic bushing in the ones i have are pretty beat up.(ill throw it in the box anyways)i think you can get a new one from the bird.
james
Series9
Jun 10 2006, 02:07 AM
That's exactly what I need.
Thanks James.
thesey914
Jun 10 2006, 02:40 AM
The Crane points replacement is exactly that? As i understand its like a 'pertronix' unit and not a seperate box like the XR700?
Is this the one that'll work with my permatune (or bosch CDI unit)
Series9
Jun 10 2006, 12:13 PM
QUOTE(thesey914 @ Jun 10 2006, 02:40 AM)
This is the first time I've used it, but I would think that it would trigger a Bosch CD box.
Series9
Jun 11 2006, 10:24 PM
Brakes are finished:
Series9
Jun 11 2006, 10:26 PM
Here's the mod to the seat rails for the GTS seat:
Series9
Jun 11 2006, 10:27 PM
Seat in the car for a test fit:
Eric Taylor
Jun 11 2006, 10:28 PM
coming along really nicely joe! Are those stock 4 rears? What are you running in the front?
Eric
Series9
Jun 11 2006, 10:36 PM
Fronts are '77 911 and rears are /4 calipers on /6 rotors.
QUOTE(Eric Taylor @ Jun 11 2006, 10:28 PM)
Eric
Root_Werks
Jun 12 2006, 11:56 AM
It's been a while since I have checked this thread. Car looks great Joe! Can't wait to see the finished product.
horizontally-opposed
Jun 12 2006, 03:05 PM
Looked back and tried to find it, but what was the need for the seat rail mod?
Thanks!
Series9
Jun 12 2006, 09:49 PM
QUOTE(horizontally-opposed @ Jun 12 2006, 03:05 PM)
Thanks!
Only one style of GTS seat is a direct bolt-in.
Series9
Jun 12 2006, 10:08 PM
Carpet in for a test fit:
RogerYellow914
Jun 12 2006, 10:16 PM
That is already a sweet looking car.
I like the bikes in the living room in the carpet photo. Is the compact frame a Giant? Before getting married, my bikes had their own bedroom.
-Roger
Series9
Jun 12 2006, 10:20 PM
QUOTE(RogerYellow914 @ Jun 12 2006, 10:16 PM)
-Roger
It's a Giant TCR w/Ultegra and the Cannondale is a CAAD4 w/full Campagnolo Record.
Series9
Jun 12 2006, 10:25 PM
Here you go.
I'm proud of this one. Forget about the R1000, I just used the frame:
Series9
And the TCR2:
Eric Taylor
Jun 12 2006, 10:33 PM
Sweet bikes joe, both a couple of great frames. What kinda of riding do you do? any racing? You should bring the bikes up to oregon for some really great riding. I've been told it's really similar to riding in europe here in the willimate valley. If you ever want I could show you some great rides.
Eric
Series9
Jun 12 2006, 10:43 PM
We're actually planning on riding home to FL next year. So I guess that makes me a long-distance cyclist.
We won't have time to ride in OR, but I appreciate the offer.
Eric Taylor
Jun 12 2006, 10:47 PM
wow joe! that sounds like a hell of an epic ride! Enjoy the trip but I hear riding your bike through the south can be interesting though. A buddy of mine did a cross country trip and was constantly harassed by cops down in the southern states. I guess they just didn't understand the idea of riding your bike that long, lol. Anyway cool bikes!
Eric
Series9
Jun 13 2006, 11:09 PM
Polished turd: The '77 ceramic coated muffer.
JoeSharp
Jun 13 2006, 11:10 PM
DAMNNNN!!!!!
:PERMAGRIN: Joe
Series9
Shift pattern taped to the dash for a couple who have never driven a 914:
Series9
Jun 13 2006, 11:11 PM
Engine deck back from paint. I have the decks and doors as well. Pictures later.
Series9
Jun 13 2006, 11:30 PM
Doors:
Series9
Jun 13 2006, 11:31 PM
Decks:
