Dr Phil -
Maybe a stupid question: as the 914 is far from an aircraft, are the safety wires really needed?
Not a bit of overkill?
Nice touch for sure on a Concours level car like yours for sure.....
GN
after installing the ford starter solenoid, new seals on the inner CV with safety wires CV bolts!
new door stay and hinge parts!
I’ve had them come loose, not dropping on to the driveway loose but still loose.
https://forums.pelicanparts.com/porsche-911...come-loose.html
In my younger days I had them come loose to the point of releasing the CV joint. It cracked the transmission case.
That being said, safety wire is not necessary if the bolts are installed with new schnorr washers and properly torqued to the correct torque spec.
But safety wire is a good piece of mine for many people.
