Jeff Hail
May 4 2008, 02:31 PM
QUOTE(Eric_Shea @ May 4 2008, 01:25 PM)
@ $479.00 that may be worth it for even one car... kinda pricey though when considering a soda blast for $600.
Cool tool.
They can be found for much less used. DynaBrade also makes a similar one for less. BTW,What did you find out on the brake parts cost?
Eric_Shea
May 4 2008, 02:50 PM
I found that the pound is $1.95 now!
They should be here at the end of the week.
http://www.pmbperformance.com/catalog/item...563/5825883.htm
sixnotfour
May 4 2008, 05:39 PM
Soda Blast wont remove the nasty seam sealer.
I just did mine and thought the blasting would remove the little I left , Nope had the body shop kid wire wheel the rest, as I was Done.
Eric_Shea
May 4 2008, 06:37 PM
Yeah I know...
Send him my way when you're done!
Jeff Hail
May 11 2008, 12:16 AM
Stripped the underside rear of the tub to metal and epoxy primed.
First I used the Wurth "flail" to remove the old undercoating. This also removed the majority of original paint. The rest I machine sanded with a Mini DA and a few spots I used Starblast media (transmount bracktets and crossmember). Then some good old fashion elbow grease hand sanding and some solvent.
I removed all of the seam sealer where the inner wheelhouse/ quarter panels meet the floor at the rear. Needed to see if any issues were under there. None found.
I did leave intact the sealer where the shock tower pockets are. Just took it down a little to have something to bite into and tidy it up.
The Kent solvent kicks ass.
Jeff Hail
May 11 2008, 02:38 AM
It's midnight and a knock at the door!
Who the hell is at my door at this hour?
Hey dude.... Whoa those came out bitch'n..........
What do I owe you?......A couple cold beer's!
It's nice when the Powder Coater is your bud! Price was right. 2 Stage Powder Coating rocks!
Jeff Hail
May 12 2008, 10:30 PM
Awesome....printed on the side of a box of Porsche Exhaust Headers. Even the UPS guy had to take time out to read it. Way cool.
AUTHOR: Walter D. Wintle
QUOTATION: If you think you are beaten, you are;
If you think you dare not, you don’t.
If you’d like to win, but think you can’t,
It’s almost a cinch you won’t.
If you think you’ll lose, you’re lost,
For out in the world we find
Success begins with a fellow’s will;
It’s all in the state of mind.
If you think you’re outclassed, you are;
You’ve got to think high to rise.
You’ve got to be sure of yourself before
You can ever win a prize.
Life’s battles don’t always go
To the stronger or faster man;
But soon or late the man who wins
Is the one who thinks he can.
Now who can guess what brand they are?
porsche914gt
May 13 2008, 12:27 AM
Stahl
New York
Right?
I remember mine had that.
Jeff Hail
May 13 2008, 06:57 PM
QUOTE(porsche914gt @ May 12 2008, 11:27 PM)
Stahl
New York
Right?
I recall that Stahl stopped making 914/6 headers although you are correct on the box. I got a kick out of the verbiage on the box.
The headers are George Narbel's (ERH) . I had them thermal coated and they shipped em in a Stahl box.
Katmanken
May 13 2008, 07:42 PM
Jeff,
Something I've been meanign to ask...
Who makes this tram gauge?
It looks like something I could use.
Ken
Jeff Hail
May 13 2008, 11:05 PM
QUOTE(kwales @ May 13 2008, 06:42 PM)
Jeff,
Ken
Champ Frame Equiptment
Google "Tram Gauges" and you will find a host of suppliers
Jeff Hail
May 16 2008, 12:12 AM
I was prepping a post and the lights went out! The site went down. It's like running out of MIG gas!
(Preview of next weeks board meeting:o)
Rt fender off. I new I had some rust at the top by the cowl. Not as bad as I expected. Fender was removed as a skin leaving the cowl extension intact.
The upper cowl extension will get cut out and replaced. Easy piece to fabricate.
I swear that piece was designed for Dzus fasteners!
The cowl itself is ok at the horizontal area but the side will need some new metal.
I used the Wurth "flail" to remove the sealer and take it down to bare iron.
The rear of the wheelhouse is fine no rust. The front of the rocker/ hinge pillar will need a closing plate fabricated. All in a days work.
Jeff Hail
May 16 2008, 12:35 AM
A really good product I have used for years is Jasco metal etch. It's a little different than metal ready. 1st its more agressive and only has to sit about 10 minutes (the instructions says 1 minute and rinse) versus some other products out there. It is very cheap in comparison to others and I think does a better job overall because it is full strength. (3/1, 2/1 with H20 or full strength as I use it right out of the bottle)
This is an excellent etching product. What it does not do ......It is not a conversion coating as it has no zinc or phosphate. If you are repairing and going directly to epoxy primer Jasco is a great product. If you are leaving metal exposed for a period you may get some flash and probably should use a zinc conversion coating even on good clean steel.
I am not fond of conversion coatings because rust is rust no matter what color it turns.
craig downs
May 16 2008, 12:37 AM
Where can you get it
Jeff Hail
May 16 2008, 12:40 AM
QUOTE(craig downs @ May 15 2008, 11:37 PM)
OSH, Lowes has it.....haven't seen it at HD.
craig downs
May 16 2008, 12:54 AM
Thanks
I've never seen it before but I'll go get some and try it.
sean_v8_914
May 16 2008, 10:19 AM
Frazee paint store has it too
Jeff Hail
May 17 2008, 09:13 PM
Cut the dead wood out of the cowl and cowl side extension.
Metal added was done in two pieces as the cowl has a step in it below the fender line. First piece in and then second piece on top just below. The weld becomes the step (really doesnt do anything)
Jeff Hail
May 17 2008, 09:20 PM
Shaping this area is a tight squeeze in the bends. The front corner of the cowl has a little rust and I will do that separately with the hood off.
Jeff Hail
May 17 2008, 09:24 PM
Make a template for the old rusty cowl extension. This is the top curved piece. The closing plate will be made last once everything is fitted.
Jeff Hail
May 17 2008, 09:26 PM
Rough fitting the upper curved extension. Needs a little tweaking at the rear and a flange added.
Until Next time!
Jeff Hail
May 26 2008, 01:42 AM
Where was I Eric?
Oh yes.
Finished the passenger side cowl repairs. Also repaired the drain trough and hood seal fence.
Jeff Hail
May 26 2008, 01:45 AM
It started raining while I was shooting primer. Not good! Had to sit there with a heat gun to force dry the epoxy primer. Car is covered just do not like to introduce moisture to the equation.
Jeff Hail
May 31 2008, 10:37 PM
Few things done during the week.
Right front wheelhouse
Jeff Hail
May 31 2008, 10:39 PM
Nothing interesting here. No rust........Primer time.
Jeff Hail
May 31 2008, 10:41 PM
Saturdays business
Front of the right rocker. I actually thought I would find more rust here than thought.
Cut out the old metal and put in some new...
Jeff Hail
May 31 2008, 10:42 PM
More primer.....
Jeff Hail
May 31 2008, 10:43 PM
Some porn for Shea!
Eric_Shea
Jun 1 2008, 12:34 PM
Nice...
brer
Jun 1 2008, 01:00 PM
So, does water drain from the front hood seal trough out through the cowl/fender gap? While looking at mine I wondered if that cowl/fender gap was for water to escape when driving full speed.
Jeff Hail
Jun 2 2008, 12:32 AM
QUOTE(brer @ Jun 1 2008, 12:00 PM)
Funny you say that. My left side has the outer fench that makes up the trough all the way back to the cowl. Right side had a gap of about 1-1/2 inches. The outer fence is actually part of the fender, the inner fence is made up with the apron.
My first thought is the right fender may have been replaced at one time. After removing all the coatings it was the original fender although a minor repair was done where it meets the door. I think this is where the rust came from. Personally allowing drainage off the side into the fender well is a good idea.
Anyhow I cut the fender off at the fence to repair this area and left the outer fence intact. Wasnt sure where to cut until the next step in body panels is completed.
Which leads to why I cut the fender in the first place....
The next saga in my build is holding to the weight plan. This is one thing I am really trying to not deviate from:
A friend who is the prop industry is letting me use his shop. I obtained the plugs which are an original set of full steel GT fenders that are on loan. You have no idea how hard it was to convince the owner to borrow these in the middle of a high dollar restoration his car is going thru now. The molds we made are done and will lay up the fenders in Kevlar reinforced Carbon fiber using epoxy resin. The Carbon fiber weave is 7 oz which is pretty thick so they will blow away any current fiberlgass part supplier out of the water and also be streetable.
People have asked why I am going this route? First is weight. Second is my cost to make my own GT fenders out of Carbon fiber are about $200 a fender thanks to access to a professional mold making shop. The last reason is all the glass fenders I have seen except for Sheridan are pretty poor quality. This is a bold statement to make but most of the glass part suppliers are getting top dollar for junk that requires so much re-working that I feel is just unacceptable. They are officially on notice now.
I can do better for less.
Loser_Cruiser
Jun 2 2008, 12:40 AM
so are these a one time deal or are you gonna be taking orders in the future?
Jeff Hail
Jun 2 2008, 12:43 AM
QUOTE(Loser_Cruiser @ Jun 1 2008, 11:40 PM)
These are one off's. Sorry!
Eric_Shea
Jun 2 2008, 08:41 AM
Ohhhhh... you've got them shaking and quaking in their boots now!
Jeff Hail
Jun 2 2008, 07:50 PM
QUOTE(Eric_Shea @ Jun 2 2008, 07:41 AM)
You make me laugh Eric
theo
Jun 3 2008, 09:24 AM
I have a question about your welding Technique, when you weld in a piece, do you first tack it in then run a steady string of tacks around the seam, or do you run a couple tacks then jump around? Btw your car looks great.
theo
Jeff Hail
Jun 3 2008, 11:31 AM
QUOTE(theo @ Jun 3 2008, 08:24 AM)
theo
Welding sheet metal is like Plate Tectonics. For seam welding a patch position and secure the part with tacks. This allows the patch to be adjusted if needed to for a tight fit which is key to a good weld. Then a series of quick trigger pulls to close it up .Sometimes I will get in a hurry and lay a bead. All depends on the part being welded, how it reacts to heat, how thin, cosmetic, structural, gun access etc. Moving around, starting and stopping controls heat at the zone.
Gint
Jun 3 2008, 09:17 PM
QUOTE(Jeff Hail @ Jun 2 2008, 06:50 PM)
Wait 'til you see him "live".
Eric_Shea
Jun 3 2008, 10:24 PM
Tip your bartenders and waitresses...
Jeff Hail
Jun 5 2008, 12:28 AM
QUOTE(Eric_Shea @ Jun 3 2008, 09:24 PM)
Word has it around here you are a class act
Are you tending bar tonight or the host?
To back up a bit to last weeks intimate conversation. Here are the spacers for using the late Carrera hubs (one inner, one outer on each side of the 914 wheel bearing). Easy enough? Rotors are also Carrera. Depending on going 20mm or 24 mm appropriate caliper half spacers required.
By the way you spelled Carrera incorrectly. Two "R's always come before the single "R". I just wanted to point that out you know. I am sure the bartender or host will volley back with a good jab just for fun. Thats getting back for the Kings Lad thing.
Jeff Hail
Jun 5 2008, 12:33 AM
For everyone else (except Shea) more instruct'iones (aka specs)
Courtesy of master machinist Mr. Ira Ramin
ChrisFoley
Jun 5 2008, 05:01 PM
Hey Jeff,
It was good talking with you yesterday. With a little prodding from Heidi I'm sure I will get your roll cage kit out before the deadline. As I told you - I authorized her to hit me over the head regularly until it is done. Here's what I found this evening when I came back to my desk, lol.
Eric_Shea
Jun 5 2008, 08:43 PM
Carrrrrerrrrra...
Jeff Hail
Jun 5 2008, 09:12 PM
QUOTE(Racer Chris @ Jun 5 2008, 04:01 PM)
Hey Jeff,
Thanks Chris and Hedi,
That rendition is exactly what I actually look like on Sunday mornings.
Jeff Hail
Jun 5 2008, 09:15 PM
QUOTE(Eric_Shea @ Jun 5 2008, 07:43 PM)
Carrrrrerrrrra...
Arrrrgh mate!
oh no, not again!
Jun 6 2008, 09:47 AM
Jeff- Did I get the nose right??? I'm a stickler for noses....lol
The beatings have commenced!
hehehe
Jeff Hail
Jun 9 2008, 10:56 PM
QUOTE(oh no, not again! @ Jun 6 2008, 08:47 AM)
hehehe
Close facsimile. Live life through humor and laugh at our foibles I say!!
Just don't beat Chris when he has a firestick in hand. It could get ugly.
Jeff Hail
Jun 9 2008, 11:25 PM
Speaking about foibles................or sh@t happens.
When Shop Equipment Attacks[u]
Visualize an older media blast cabinet with old seals and 25 pounds of aluminum oxide media decides its time to relocate to another zip code at 100psi?
Yes it did happen and took me 4 hours to clean up the mess today. Aluminum oxide is technically not hazardous but aluminum dust is well quite the pyrotechnic ingredient.
In the middle of this mess my good friend pulls up in the drive way (ironically he blows stuff up for a living in the special effects industry) and see's me with the shop vac cleaning up. He reminds me of the aluminum dust issue and motors that use brushes (spark) and exclaims" no,no, no you need to sweep". Cleanup time doubled. Like I said sh@t happens.
This was supposed to be a week off for vacation and I end up cleaning the garage?
Yeah I know Shea is grinning. Like I said you just have to laugh at stuff. It happens. After the fact I laughed too, especially since I looked like the tin man in the Wizard of Oz wearing a respirator.
oh no, not again!
Jun 10 2008, 03:16 PM
No prob, mon!
When you see him with one in his hand, let me know, will ya?
hehehe
Eric_Shea
Jun 10 2008, 04:17 PM
Ut uh...
I would have kept using the vac. It would have been cool
