QUOTE(doug_b_928 @ Dec 30 2018, 05:35 PM)
Happy New Year Jeff. In post #245 on p. 13 of your thread, you document applying Wurth Seal/Fix to the underside of the door sill and around the sill triangles. Would the Wurth sprayable seam sealer work as well as the Seal/Fix in that location? Also, do you apply a thin amount of seam sealer on the top side seam where the sill meets the inner rocker/longitudinal (to prevent water from getting under the sill and being trapped underneath by the sealer that has been applied from the bottom side)?
Hey Doug! Happy New Year.
Sitting here watching the Jeff Beck story:"Still on the Run".
Sprayable will work as well although not much volume comes out of the gun at low pressure.. After primer: Mine was a thin bead and then sprayed over with the Wurth (spit gun). As far as between the sill top I just used a copious amount of weld through primer on both surfaces since its sacrificial and has a low melt temperature. I sprayed a thin coat second time after welding to hit the edge of the sill and let it creep in.
