914fahrer,
Thanks for the picture and suggestion...makes sense. I am thinking now that my battery support and tray were either modified (repaired) or replaced. The tray itself was poorly mig welded underneath to the support. And the same person repeated the poor welding when the tray was welded to the inner wheel house. I believe the factory spot welded the tray to the inner wheel house as well as put a small bead on both ends...which I will also do.
I then called Peter at RD to ask if the "uphill" flange on my repaired battery support was pointing the wrong direction...in (to the left). He kindly sent me some pics of a factory longitudinal with the support, but without the battery tray. Voila! looking down into the support, the "uphill" flange did indeed point to the left.
I then watched the RD battery support install on Youtube. Adam did spotweld the left and facing sides of the support, but as he had already assembled the tray to the support, he did not weld the uphill, flange as it was inside the support. He aslo did both spotweld the rear lip of the tray, and put a bead on both ends to connect it to the inner wheel house.
My plan is to clecoe the tray to the support and line everything up. Once satisfied with the position on the long, I will spotweld the left and engine facing flanges. Then I will remove the clecoes and the tray, so I can weld a bead on the "uphill" flange inside the support. Finally I will spotweld the tray to the support, and the tray to the wheelhouse.
Comments are welcome...criticism too!
