sixnotfour
May 27 2020, 07:25 AM
QUOTE(Speedo @ Mar 23 2020, 02:59 PM)
Still thinking about oil coolers. There is a local guy to Denver doing some interesting re-configuring of the old trombone coolers. They can be made in all kinds of contorted shapes and they are always in the airflow. And they were pretty effective at dissipating heat. Anybody have pics of these being used in 914's before? And I presume they are made of copper with soldered fittings?
IDK...but here is one,, maybe in the pas. fender well?
http://www.914world.com/bbs2/index.php?showtopic=188776
Speedo
Jun 2 2020, 02:28 PM
Scheduled to go check the car out in primer this Friday. I am wondering if the seam sealer and undercoating (where both are needed) are ok to be applied after primer? I was wondering if they should be applied before primer. If they are applied after primer...should those areas be resprayed with primer before color?
Also going to pic up two trombone coolers to try to engineer a system underneath the rear of the car to help keep the 2.4 cool(er). If I kill one, I'll have a backup
Cairo94507
Jun 2 2020, 04:55 PM
That is my car above with my original oil cooler system on my Six running a 3.0 w/Webers. According to the 2nd owner it never overheated and he used to traverse the Santa Cruz mountains regularly in the summer.
Speedo
Jun 3 2020, 06:25 AM
I just realized that my car is missing the rear valence. Was it supposed to have one or was that an option? If it came with the six and it is missing, I need to source one quickly.
Speedo
Jun 26 2020, 06:22 PM
After spending three hours under my car priming the recently re-sandblasted floor, I realized my 1970 chassis does not have the oil line hook. Did all 6s get them, or some not? Do I need to source one?
porschetub
Jun 26 2020, 06:53 PM
QUOTE(Speedo @ Jun 27 2020, 12:22 PM)
Easy enough to make for a man of your skills
Jun 26 2020, 06:58 PM
I think RD and McMark sell them.
Cairo94507
Jun 26 2020, 08:37 PM
As far as I know, all Sixes had the oil line hook. Well, I can only really confirm '70 & '71 had therm, I have not owned a '72 Six.
Speedo
Jun 27 2020, 07:09 AM
Ok, I need to get one of those on the chassis before it gets paint. I also need to source the front trunk plug as mine has gone missing. Does anybody have dimensions by chance and measurements for positioning that piece? Why is it that I am only now discovering all the schwagg I need that I don't have...now that my car is at paint? Have two more small items to mig...close up the emblem holes on the front hood, and thr extra holes in the door top for the Vitaloni mirrors that will not be re-used. Color is imminent.
Speedo
Jun 27 2020, 07:11 AM
Speedo
Jun 27 2020, 07:12 AM
Speedo
Jun 27 2020, 07:13 AM
Speedo
Jun 27 2020, 07:16 AM
I guess the quick way to figure out the oil line hook would be for me to measure someones six for both the hook dimensions and location. If anybody in the Denver area has a six available I would appreciate it...there is beer in your future. With a mask of course!
brant
Jun 27 2020, 07:34 AM
Lars,
it looks good.
ferg might be able to hook you up with a -6 owner
also I need to introduce you to Ginter
he has a -6 over here closer to me.
brant
Luke M
Jun 27 2020, 12:04 PM
Hi Lars,
The 6 looks good and coming along nicely.
The hook gets welded by the left rear suspension reinforcement plate. On my 914-6 there's a 5 mm gap between the plate and the hook. Posted a few pics for you.
Which trunk plug do you need? Is it the one on the trunk floor that turns and locks?
I may have a spare if so. The hook is being made and sold by RD.
gandalf_025
Jun 27 2020, 01:07 PM
Another set of pictures
Speedo
Jun 27 2020, 06:47 PM
Thanks for the pics guys...why would the PO (or anybody) remove the "hook"?
Yes I think the front trunk circular plug is the one that turns and locks? I will look in my sons car tomorrow.
restore2seater
Jun 29 2020, 09:54 AM
QUOTE(Speedo @ Jun 27 2020, 07:47 PM)
Sent you a PM.
@Speedo
Speedo
Jul 1 2020, 09:06 AM
So "restore2seater" graciously sent multiple pics and dimensions of his oil line hook
and I was able to fabricate the "hook". My new short term dilemma is sourcing the two drain plugs/plates for the front trunk. Per Porsche these are NLA so my only option is to harvest these from another chassis. My understanding is that once the old seam sealer is wire-brushed off...they can be tapped out easily. I will post in the classified section a WTB, but in the interim if anyone has these, please send me a PM. The picture is of my son's 72 1.7, and I'm pretty sure he doesn't want me to steal these from his car.
Jul 1 2020, 09:11 AM
Yes, the seam sealer (other than rust) is the only thing that secures them.
Speedo
Jul 1 2020, 10:38 AM
Oil line hook attachment question. In the first two pics of the green chassis, it looks like the hook is "butt" welded to the edge of the flange. In the second set of pics it looks like the hook lays over the flange and is welded at the base to the outside of the flange. Which is correct? I fire up the Lincoln in an hour
sixnotfour
Jul 1 2020, 11:00 AM
lays over, factory is spot welded to existing flange..pancake #41
Speedo
Jul 1 2020, 11:24 AM
That looks like it is spot welded to the inside of the flange? Not the outside?
sixnotfour
Jul 1 2020, 11:49 AM
#390 I bought from Steam Boat Springs, CO. 1978
1st pic engine compart. out
2nd pic outside looking in
mig it,, leave a hanger..
@speedo
Speedo
Jul 1 2020, 06:17 PM
Mig welded the hangar. Spent the afternoon with chassis black. Friday is undercoating. Then color. I'm getting burnt on the underside of this car.
Cairo94507
Jul 1 2020, 06:51 PM
Going to be well worth it when it starts to go back together.
Speedo
Jul 3 2020, 04:09 PM
preach
Jul 3 2020, 04:26 PM
Oooo, nice color!
Speedo
Jul 4 2020, 05:07 PM
Making sure my painter has all my "bits" and starting a pile of parts for refinishing. Curious about clear vs yellow zinc...my internal door latches are obviously yellow, but it looks as though my lid and trunk latches are clear? Which is correct? Sure would be easier if all the hardware was either clear or yellow. And in one of my boxes I ran across this parts which I cannot identify (looks like it was refinished yellow). On a 911 it reminds me of a bracket that supports the fresh air vent. Can someone id this for me please?
Speedo
Jul 4 2020, 05:08 PM
zoomCat
Jul 4 2020, 11:54 PM
It looks like the bracket that holds the front turn signal into the fender. I may ba able to get a better pic tomorrow.
BPic
Jul 5 2020, 05:45 AM
Speedo
Jul 5 2020, 12:43 PM
Yeah, that's what it is and why I have two of them. Yellow plating?
BPic
Jul 5 2020, 01:03 PM
That’s what I did. But not sure if it’s correct.
914Sixer
Jul 5 2020, 08:35 PM
Yellow is correct color
Speedo
Jul 6 2020, 08:30 AM
So to be clear...any metal refinishing is to be yellow? No clear used anywhere on car?
Speedo
Jul 18 2020, 02:15 PM
Speedo
Jul 18 2020, 02:16 PM
Speedo
Jul 18 2020, 02:17 PM
Speedo
Speedo
Jul 18 2020, 02:20 PM
Now time for the cockpit. Have to do this by hand. Before....
Speedo
Jul 18 2020, 02:24 PM
Speedo
Speedo
Jul 18 2020, 02:25 PM
Speedo
Jul 18 2020, 02:26 PM
Speedo
sixnotfour
Jul 18 2020, 02:28 PM
Beauty...just installed an engine..in one the same color
BPic
Jul 18 2020, 02:39 PM
Speedo
Jul 19 2020, 05:32 PM
Putting together a box of parts to get plated. Basically 99% of the plating will be yellow zinc. I only have a few bits to be clear. Door striker and targa latch...anything else?
Speedo
Jul 19 2020, 05:34 PM
