Click to view attachmentAnother drawing,top view.
Compact,low,easy install,the existing bulkhead is used as an attach plane for the supplementary top beam,in two pieces,fastened to the bottom beam.
Forms a w truss,transferring the loads to the unibody,adjustable by shim and sliding key.
A reinforcing channel or tube can be added on the rear of the bulkhead,as it has been chopped to clear the bonnet.
The factory fuel tank likely must be sectioned to clear the hood,the filler neck re-positioned.
The steering rack is in the factory position.
The boxed ribs carry the noses of the shortened top arms,adjustable by shim and slots.
Click to view attachment(edit:01/22/16) 914 chassis cut to remove 150 mm from wheelbase to match the 904's 2300 dimension.
Closely scaled,+/- 1.5mm,1/16",gimped.
Clearly,the shortened strut will clear the 904 hood,the travel sufficient.
The torsion spring appears to have enough room too.
Smooth sailing ahead,now,about that wishbone 914.
Some good advantage,a rising rate of camber and allowing a wider tire without the constraints of the MacPherson struts.
The more I look at it,the more I like it.
I know of only a few 14s that have made a conversion.
The nice part is the use of factory parts,hacked and welded.
