Adam, maybe I missed it, but did you you sleeve the longs when you joined the two halves back together?
Unobtanium-inc
Dec 6 2020, 08:55 PM
QUOTE(FL 000 @ Dec 6 2020, 05:26 PM)
No, because most of them will still be cut to accept the 904 door. I plan to box the whole inside with plate steel, then make my final outer cuts. Here is what the practice car looked like.
Unobtanium-inc
Dec 10 2020, 06:49 PM
Nothing crazy this week. After the cutting the car in half head game I decided to take it easy and tackle something that won't take much thought. Time to eradicate the yellow. I've always hated the yellow, and being a former racecar, EVERYTHING IS YELLOW!
Building a custom, makes for measuring twice. The shortened wheelbase affecting the steering geometry, slightly. I am loving this build, the 904 a desired object of art.
Unobtanium-inc
Dec 11 2020, 10:20 AM
Because everything looks better in black!
Unobtanium-inc
Dec 12 2020, 04:36 PM
Well, it's tight but not too tight for a 10 year old! The kids went with me to the shop today and Max got to sit in the car, still too big for him.
They employed the same construction method, the wire form. I think more people are adopting this method over the traditional wood buck. The wood buck doesn't give you the ability to join panels as well, or clamp the panel for fitting. The 550 is coming along nicely, I've secured about half the body in original metal, the rest we have made. I found a fender recently, the guy hasn't decided if he will sell it yet, but I'm on it. So far I have the tail off of 0058, the doors and inner fenders off of 0132 , and the hood off of 0114.
Unobtanium-inc
Dec 22 2020, 05:38 PM
Tomorrow is going to be fun. Picked up the plate steel to box in the inner cockpit, before I cut the outer longs. I got 1/4 inch, maybe overkill but I want it to be strong.
mate914
Dec 22 2020, 07:18 PM
QUOTE(Unobtanium-inc @ Dec 22 2020, 06:38 PM)
I want to help/learn. I hope I'm not too far away. Teach me
mb911
Dec 22 2020, 07:23 PM
QUOTE(Unobtanium-inc @ Dec 22 2020, 03:38 PM)
Make sure you have the welder set correct for 1/4" 19 volts 300 ipm would be a good setting for thick to thin
tygaboy
Dec 22 2020, 07:46 PM
I'd suggest 1/4" is way too thick. If you're talking about replicating the "traditional" inner long/lower firewall stiffener, kit you'd be more than fine with 16 Ga, 14 at the most. You're adding a TON of weight that isn't doing you much more good than 14 or 16.
Or is this just temporary while you work on the outer longs? If that's the case, you'd be better off with something like Tangerine Racing's door brace kit. I had both my outer rockers off with just door braces and it worked just fine.
Unobtanium-inc
Dec 22 2020, 08:12 PM
QUOTE(mb911 @ Dec 22 2020, 05:23 PM)
Thanks for the tip.
Unobtanium-inc
Dec 22 2020, 08:18 PM
QUOTE(tygaboy @ Dec 22 2020, 05:46 PM)
I'm trying to add some hardcore rigidity to the center mass of the car. I cut away so much of the car, and the fiberglass body is very thin and will add little if any substance. I also wanted some solidness in case of a crash, again the fiberglass won't help. In order to have the door pockets for the body fit I have to cut all the long off, everything but the inner wall, which is what I'm hoping to strengthen. Look at the pics of the test body, you can see how the long gets cut to ribbons.
Unobtanium-inc
Dec 22 2020, 08:21 PM
QUOTE(mate914 @ Dec 22 2020, 05:18 PM)
Let's talk once Covid is over, the shop is pretty much closed now.
rhodyguy
Dec 23 2020, 08:12 AM
In case of a crash? "Over"?
Unobtanium-inc
Dec 23 2020, 02:02 PM
Was hoping to get the pieces welded in today but ran out of day and out of metal. The metal place cut one piece down for me, and gave me the short end, not the long end I paid for, so I'll swap that out today on the way home. I did get the two side pieces cut and fitted and the cardboard template is in for the firewall piece. Hoping I can sneak out of the house this weekend and get up to the shop and finish this part up. Here's hoping!
Happy Holidays!!!!!
Carbon-14
Dec 23 2020, 02:20 PM
Click to view attachment Monocoque or tubular structure, a beam, stiffening the platform. Attaching the ends and edges to the existing remains of the 914 chassis must be accomplished by spreading the loads to larger areas, adapter plates and bulkheads of similar thickness light sheetmetal.
Click to view attachment https://www.restoration-design.com/store/product/PP301R Emulating Porsche's perimeter box rails attached to the 914's pan, elegantly. The corrugated and bossed panels when welded to a clamshell beam with internal integral stiffeners transfer the loads to their ends without buckling and are relatively lightweight. Some modifications will be necessary to fit beneath the 904 grp siderails. Measuring the diagonal stiffness of the resulting weldment will determine the performance characteristics of the chassis. Looking good.
Unobtanium-inc
Dec 23 2020, 09:01 PM
QUOTE(Carbon-14 @ Dec 23 2020, 12:20 PM)
Thanks for the input and graphics. I was a little confused at what you were saying. Are you saying I'm on the right track with the inner pieces I made, or I should get a piece from RD and start with that?
Carbon-14
Dec 24 2020, 07:34 AM
Your solution will work just fine, welded securely to the chassis, like the armor plated hulls of battleships.
Plenty stiff in torsion, a good thing, though with a weight penalty, and likely still below 1800 Lbs ~ 820kgs, all good.
Pressing the plate steel into an L shape would have added substantial rigidity, making holes to lighten the plates would benefit the power to weight ratio, which should approach that of the 904's. '..for what I got, a carbed 3.2, with a sequential gearbox...' A centrifugal blower, to get the power up, heh heh, a blown injected 914/904. https://www.youtube.com/watch?v=t9JB6jRSZD4 Press on regardless.
I like both. Keep the 1/4'' steel and with the clamshell make a boxed frame. Maybe run heating through the small boxed frame to clear windshield. Would also be a safe place for oil lines. Looks great.
Bruce Hinds
Dec 24 2020, 11:39 AM
That was going to be my question: Why not put the plate on the outside of the inner long to make the C section a D section? Seems like the D would be stronger and only make the thing a 1/2 inch wider.
Unobtanium-inc
Dec 24 2020, 01:10 PM
QUOTE(Bruce Hinds @ Dec 24 2020, 09:39 AM)
I had no room to spare on the outer wall, the body barely fit. My solution was to strengthen the last remaining wall of the original long, thereby still having all the original structure, factory spot welds etc, but making the whole thing super strong with the thick steel. The similarities of the 914 and the 904 are great, but there are times when they diverge pretty dramatically. Probably because one was a purpose built, low production race car, and the other was a production car made for the masses. I'm just glad I'm not terribly tall, because anyone much taller than me (5'9") would have a really hard time in this car.
Bruce Hinds
Dec 24 2020, 02:00 PM
QUOTE(Unobtanium-inc @ Dec 24 2020, 12:10 PM)
Understood - such a cool project. Thanks for sharing . . .
Unobtanium-inc
Dec 26 2020, 04:08 PM
Ok, was able to sneak away today and get the plate steel cut fitted and welded in, so all in all a pretty good day. I need to finish out the welding but for now nothing is going anywhere and the fit was pretty good. It was nice to turn up the welder (thanks mb911) and do some real thick steel welding. It reminds of when I took my welding class in Brooklyn so many years ago, thick welds that were nice and flowing. It's a lot harder to get those kind of welds on 60 year old cars with sometimes questionable metal that is thin in many spots. This was welding like it was intended to be, a slow flow of metal, joining two thick pieces. It was quite refreshing!
Hope everyone had a nice holiday!
Unobtanium-inc
Dec 27 2020, 09:55 AM
One last shot, wouldn't fit the first round.
mate914
Dec 27 2020, 11:13 AM
That is the ultimate inner long kit. The one time I saw a real 904 it was tiny compared to my teenier. Looks good....
Unobtanium-inc
Jan 14 2021, 02:20 PM
Ok, holidays done, back to work. Meaning it took me several weeks to get a day to work on my own stuff. I welded in the plates all the way in anticipation of cutting out the rollbar and the outer longs. I got the rollbar out, as well as the driver's side long. So you can know see why I had to really really reinforce the longs, because there is nothing left!
I think I have to jump back on a 911 tomorrow, but I might split the day, or come in this weekend, so be on the lookout for more updates.
Happy New Year!
Unobtanium-inc
Apr 18 2021, 05:42 PM
No new work, but I recently did a buying trip through VA and stopped off to see my friend Bob Garretson to get him to sign the dash. He had some great stories of racing 935's and the like. Bob and Bruce Anderson originally built this car for IMSA racing.
Unobtanium-inc
Oct 25 2021, 03:31 PM
Ok, the selling season is officially over so the "winter work on your own shit" period has begun. I moved the chassis to another part of the shop today, bigger space but it's next to the wood stove so it will be a hot winter of welding. Expect regular updates until Spring when we will start pumping cars again.
Superhawk996
Oct 25 2021, 04:16 PM
I've followed this thread off & on. Looking forward to progress.
But . . . wouldn't it have been easier to just start a tube frame.
Keep going. Can't wait to see this one shape up.
Unobtanium-inc
Oct 25 2021, 04:29 PM
QUOTE(Superhawk996 @ Oct 25 2021, 02:16 PM)
Because then it wouldn't be a Porsche. Might as well just buy a Beck and save myself years of work.
KELTY360
Oct 25 2021, 05:49 PM
QUOTE(Unobtanium-inc @ Oct 25 2021, 03:29 PM)
Doncha just love trouble makers?
Rock on Adam; should be some great progress this year.
Unobtanium-inc
Dec 9 2021, 06:56 PM
Ok, winter has officially arrived here at Unobtanium HQ, so let the winter of welding begin. Hoping to start dry fitting the body before the new year. The last cut of the passenger side rocker is complete. Here's to winter!
ctc911ctc
Dec 11 2021, 02:18 PM
Perhaps I am the only one but I see a bunch of very interesting projects in that bone yard of yours.....
Unobtanium-inc
Dec 11 2021, 02:40 PM
QUOTE(ctc911ctc @ Dec 11 2021, 12:18 PM)
They normally don't last long, if you look at the yard a year from now it will be different cars. We like to see them leave, almost more than we like to see them arrive.
Sedonut
Dec 11 2021, 06:15 PM
Thank you for posting all this. I love seeing what can be done so I learn something !!
Thanks again !!
Shivers
Dec 12 2021, 08:02 AM
What's all that white stuff? Been following
Unobtanium-inc
Dec 12 2021, 09:56 AM
QUOTE(Shivers @ Dec 12 2021, 06:02 AM)
This shop isn't that bad, the old shop was in the Adirondacks, we would get feet of snow, all you could see was the shape of the cars!
Unobtanium-inc
Jan 12 2022, 08:18 PM
Ironically it is 6 years to the day when I dry-fitted the body to the test bed chassis because today I started to fit the body to the real chassis. Guess we will find out this week if I cut and welded in the right places. Stay tuned.
Unobtanium-inc
Jan 13 2022, 01:27 PM
Ok, so it fits! Fine tuning it now but everything is lining up just as I had hoped. Like Hannibal Smith used to say, "I love it when a plan comes together!"
930cabman
Jan 13 2022, 07:52 PM
Not for the meek!!
Looking good, what is your target weight?
Unobtanium-inc
Jan 13 2022, 07:57 PM
QUOTE(930cabman @ Jan 13 2022, 05:52 PM)
Not for the meek!!
It won't be much heavier than it sits right now. I still have to put a tank in it and I'm using Speedster seats so no real weight there. Wonder where it will end up?
914Sixer
Jan 13 2022, 08:47 PM
Badass all the way!
djway
Jan 13 2022, 09:31 PM
Looking at that steering wheel really shows how small this car is. Great job.
Unobtanium-inc
Jan 13 2022, 10:30 PM
QUOTE(djway @ Jan 13 2022, 07:31 PM)
When I first got the body I thought something was wrong, it was too small. I'm not a big dude, 5'9", but it was tight. Then I sat in a friend's real 904, 0014. Nope, they are just really small.
Jonathan Livesay
Jan 13 2022, 10:41 PM
QUOTE(Unobtanium-inc @ Jan 13 2022, 05:57 PM)
Not for the meek!!
Maybe he meant your target weight for being able to steer and shift at the same time?
Unobtanium-inc
Jan 13 2022, 10:46 PM
QUOTE(Jonathan Livesay @ Jan 13 2022, 08:41 PM)
Not for the meek!!
He had me at "looking good".
930cabman
Jan 14 2022, 07:01 AM
I must be an old guy because I can recall seeing a 904 available for sale, probably mid '70's
Very cool project, I assume being completed in your spare time
mate914
Jan 14 2022, 07:33 AM
I like it. Out of the true spirit of the 914 comes a fire breathing dragon. Matt
