QUOTE(rick 918-S @ Jan 17 2023, 07:05 AM)
Clay suggested I use a Boxster transaxle. Kent and I were talking about the the Subaru swap and he posted photos of the subaru unit as well. I have been thinking about changing out the 901.
Me too for the Nissan swap, target is 290 hp 270 tq. Also I posted weights somewhere. Suby is 100 lbs. 914 85 lbs. Box6 is 175 lbs iirc. I want to be able to flog it without concern and solid shifting would be nice for a change.
QUOTE(ClayPerrine @ Jan 18 2023, 06:16 AM)
How does the length of the Subi trans compare with the 901 and the Boxster 6 speed?
914. ~22" at the mount center bolt. ~24" at the muffler bracket mount.
Suby. >26" at the case plate w/ 2wd swap. ~28" at the shift rod. Diff is forward 1 1/2", looks like that will put you back to stock axle geometry.
You might find the German to German swap easier in some small ways. I had that benefit with my Japanese to Japanese matchup. The problem I had with the Box5 is the small flywheel/clutch vs the Nissan.
