Before I attempt to weld in the cowl flange on the right I go ahead and set/hold the correct depth on the left with a self tapping screw.
Click to view attachmentHaving that done that I went ahead and got to right side all set and tacked on the flange.
Click to view attachmentAs I begin the vertical repairs on the cowl to hood channel I determine that I might need some more 20ga so I make a run to the Industrial Supply store here in Forest Grove and raid the scrap pile. Which is all you need for most of our repairs.
On to the vertical portion of the what I'll call the cowl to hood channel. The big one at the top of the hood. Back to the workbench. I'll start with the right side.
Click to view attachmentSlow going. Blip. Blip. Blip. Good solid steel all way across.
Click to view attachmentClick to view attachmentClick to view attachmentTool Whore moment : Roloc Discs. I've progressed from Hf/Chinese to Norton and finally to 3m Cubitron II. This was done with 80gr on a Snap On 2 speed prep tool.
Run at the low 6k speed as to not cut to fast. Bought both of mine on Ebay $50 and $70. The Cubritron cut the cleanest and the edge lasts the longest. Amazon. Last box of 50, $38 on sale.
https://store.snapon.com/Micro-Sander-and-P...t--P648542.aspxBoth Eastwood and TP Tools are making their own version now.The line on the bottom is my sanding line. I'll grind/sand up to that line for a starting point for the next right angle channel portion. 20mm down from the top.
On to the left side.
Click to view attachmentAs you can see I ran into some bumpy stuff. I had about an inch of less that stellar steel. This is where Super In Law gets really frustrated. If you blow up a stitch. STOP.
Cool yourself and the steel down. Then go back and try and put super small blips on the edge of the hole. Circle the hole. Then fill in the top, from the bottom up if you can. Hard to do. But it looks better after you sand/grind it down.
End of the day .............
Typical work day at MiddleMotors is 10am till 5pm with an hour lunch away from the shop.
I have to keep Super In Law fed and filled up. LOL. So we have a 6 hour work day. With me usually tinkering with shop stuff for an hour, so most
work days are 5 hours. But until we get both Doug and Taylor's cars done, it will be 6 days per week. 3 at Rothsport and 3 at MiddleMotors.
I hoping I can go play hooky from Rothsport another week. Gamroth will be heading to SEMA. He'll be in/on the 400R display.
http://www.motortrend.com/news/guntherwerk...93-porsche-911/http://www.motortrend.com/news/guntherwerk...93-porsche-911/Rothsport 4.0 with over 400+ reliable long term horse power.
Some day we'll build both a 1977 and a 2056 Rothsport MOTEC 914 Type 4.
Wont be cheap if we use this as a starting point.
https://type4store.com/engine-kits/2056-120-porsche-kit.html
