Did I think I would spend an entire afternoon yesterday on my accelerator linkage? Nooooooooooo
Disclaimer on the following posts “my linkage may be different than your linkage”.
Thought it might be a good idea to check out my carb linkage while the engine still easily accessible.
Turned out to be one of the best decisions I could possibly make!
As I got into it I thought I would document my Weber carb linkage set up.
Maybe someone has posted it on the site already but I couldn’t find it.
I am a lousy searcher.
I learned so much in the process and if I had waited to do this after the engine was installed I would have been up and down and a half million times and needed a second person to help and it would have been a real pain in the ass! I can see that now.
To Start:
Tried to put my linkage on. Didn’t get far. Unfortunately my linkage has been sitting for several years now and that sitting had taken its toll. The linkage arm ends that go on the pivot balls were dried out inside, and they were corroded plus that little cir-clip inside the linkage arm end that captures the ball was non functional. Stuck in its groove.
OK so stop right there and clean up every linkage end and polish up the little pivot balls. Unfortunately, I neglected to take pics of all that ugliness.
Key is cleaning all linkage attachment points and applying a good grease to every moving part.
While you are at it, make sure the rod ends work freely in the threaded part of the linkage arm end as well. Mine did not, some only screwed in half way. Make sure they actually screw in all the way because you just may just need that last bit of thread as I later discovered. WD40 is your friend here.
Click to view attachmentClick to view attachmentI needed to turn a difficult/ stuck rod ends and a 10 mm open end wrench works great for that. Protect that rod in a vise.
Click to view attachmentNext step, install the brackets for the cross bar to the intake manifolds followed by the cross bar.
As you know these are new intake manifolds in my case so who knows how this will go? I mean this was all together once but with different manifolds. Should still work though, right?
Now with the uprights loosely installed and grease in the sockets and also on the cross bar ball ends, tighten the bolts to the manifolds.
Nope, not even close to rotating freely.
Bit of tweaking on the uprights to release the inward pressure on the bar to free it up but still just enough tension to keep it well contained.
