QUOTE(rgalla9146 @ May 2 2019, 05:24 AM)
My mag case 915 with the Bott kit has been assembled for years but not
yet installed. My excuse being I needed to build the car to put it in.
Anyway, the shaft support you focused on needed attention in my box too.
I had to locate and tap into an existing boss. Not the end of the world.
As I recall Chris Foley had to create a boss by welding.
The time consuming issue for me was that that support had to be shimmed off its
mounting surface to allow the shift console to fit flush on the case.
I have to see if I have pics of the assembly.
This thing looks filthy.
Thanks for weighing in on my thread. I saw you had done the Martin Bott kit and kept meaning to reach out to you about it.
This site is awesome!
I have since my post, been in touch with Martin and he has assured me I have the correct part for my alum trans and that his included template should do the trick. I was concerned about exactly what you were talking about, that even with the template, the shift console fits flush! Couple that concern with Steve having problems with his and I decided to do all I could to ensure success and make things as straight foreword (ie keep the cost down) for my trans guy.
Martin is very responsive by the way.
I knew I had to have the boss drilled and tapped but the location became a concern. Hopefully this issue will be tackled soon, it's just other things have gotten in my way.
Can't wait to get this into work. Thanks again.
