QUOTE(Puebloswatcop @ Dec 31 2021, 05:38 PM)
QUOTE(Luke M @ Dec 31 2021, 06:13 PM)
I can tell you that after having my brothers 914 blasted it did not remove the seam sealer. My brother removed some from the front trunk but left the area under the cowl alone. The blasting didn't touch the seam sealer at all. The blasting sorta cleaned the areas where he used the heat gun and scraper. He had to go back and hit the areas with a wire wheel to remove it all. As for seam sealer we used a product called Sure Seal. It comes in a calk gun tube then we spread it with a hard bristle brush. We also used epoxy primer in the areas prior to adding the seam sealer.
Car looks great. I know installing flares can be a pain to get just right.
Thanks Luke. I noticed in all the posts that the seam sealer stays intact, but I really hope the tar coating will come off. I started sealing the floor plugs etc., with Tiger seal from Upol, but the tubes I got were old so it was very difficult to use, so I returned them. How did you like the sure seal, and do you know who makes it? I am planning on doing the 2 part Epoxy primer as well.
It's called Dominion Sure Seal LTD. Made in Canada
Code : 9002 , Stock : CSW
I picked up the tubes at a local auto paint supply store.
Spread pretty well. I used the calk gun to apply and my brother behind me spreading it around. Dipped brush in mineral spirits to keep the sealer from sticking to the brush. After a while went to the finger spreading method..
Dries fairly quick too but we let it cure 24 hrs before painting over it.
