QUOTE(Literati914 @ Mar 11 2022, 08:44 PM)
Hey Kevin, is that the same bar clamp you used for the A-arm assembly? If so, what size do I buy.. ? (to accomplish the same two jobs)
Also, was the interior (tube) of the pedal assembly protected from powder coating or not? Id think the bushing fit could be a problem if not, but it looks like the interior got pc too from the pics.
Good Morning Doug
The clamp is actually a pipe bar clamp. I have a 48 inch bar, which is really overkill, but it's what I had. I would say a 24 inch will do both jobs and be a bit less clumsy to work with. Just make sure when you buy the clamp portin that it has the plastic covers that go over the steel so it is less likely to cause marring of the items you are clamping.
I did forget to tape off where I didn't want the PC to be on the inside, however the PC guy was smart enough not to actually spray the inside, so it was just light overspray. I was able to sand it out for the most part, so the bushings had a slight interference fit inside.
The bushings actually went in pretty easily I just didn't like the idea of putting them in without the proper size drift, so chose to press them in. In the one picture you can see the socket laying there, that is becase the flange on the clutch tube interfered with pushing the bushing in all the way, so I used it to get the clamp to a point where I could get the bushing in all the way.
