QUOTE(Puebloswatcop @ Sep 28 2022, 05:04 AM)
QUOTE(bkrantz @ Sep 27 2022, 07:02 PM)
Howard, in case you have not already planned to, I suggest mocking up the fit of the cylinders and pistons, including any cylinder gaskets, and measuring the deck height, both for absolute depths and consistency for all four.
Thanks for the advice Bob. I will do exactly that. Also, do you have any advice on how I can check the valve clearance from the pistons? I have oversize valves in the heads and want to be sure I don't plant one through the top of a piston.....
You can put some soft clay on top of the pistons, assemble everything, including heads and rocker assemblies, manually turn the motor through several cycles, and then take the heads off. Or do what I did and measure (guesstimate) valve clearance, and then use a bore scope stuck in the spark plug holes to see how close the valves get to the pistons.
