So I know I said I would post the step by step on how to rebuild your CV joints on your rear axles. However I don't believe in re-inventing the wheel, and I see that Ian Karr has already done a great video on the subject. I guarantee Ian is allot more fun to watch than people listening to me ramble. Here is the link:
https://youtu.be/F-5Xpug52QwThe only thing I would recommend is when you remove the stub axle, is to partially thread the bolts back into the holes and use a soft hammer (I prefer a plastic end) to tap the stub axle loose rather than use a screwdriver. I can't tell you the number of joints that I have seen that are all gouged up because of screwdriver use.
The other thing is to pay close attention to getting the narrow part of the cage alligned with the wide part of the housing. Believe it or not it can be assembled with the narrow and wide parts alligned, but if you run it that way on your car it will destroy the the joint and probably allot of other things in the process.
Click to view attachment The best way to insure you have it correct is to see if you can deflect the cage in and out of the housing (both ways) without it falling out. If you can't deflect the cage, look closely and you probably have the wide portions alligned with the large and the small with the small.....
Click to view attachment Click to view attachment
