JmuRiz
Mar 4 2015, 09:01 AM
Very nice!!! Much better than an f'glass reproduction!
If my under the rear trunk cooler with fans does not suffice on my engine, I'll go front trunk and want one of these also!
914350
Mar 4 2015, 10:48 AM
Sweeeeeet...love it!
rgalla9146
Mar 4 2015, 11:21 AM
Now that you'e done one the second will be easy.
When can I pick it up ?
Mar 4 2015, 12:50 PM
QUOTE(rgalla9146 @ Mar 4 2015, 12:21 PM)
Wait in line buddy
we all.know cairo's car is just practice for mine.
76-914
Mar 4 2015, 05:25 PM
I
this kind of
. I would like to see the equipment in action. Does the metal shrink/pull proportionally with the depth of the channel?
QUOTE(scotty b @ Mar 3 2015, 09:06 PM)
alittle something that has been in the works on and off for a few weeks now. My bead roller isn't deep enough to get to where I needed the beads so I've been trying to coordinate with a good friend in northern Va to come up and use his roller. Between the weather and each of us getting sick at different times it's taken a while, but today was the day. Unfortunately I forgot my camera so I only had the cell to take pics with.
I still have some final fitting to do, and finish bending the flanges, when I am back at the car and I'll get better pics then. But for now here's some teasers. Gotta practice my Al welding before I go much further too. Been about 8 years since I've done any Al
Well aren't you a fancy pants.
Nice work, suh, very nice work.
Cairo94507
Mar 4 2015, 05:55 PM
It's is not going to get painted- it will end up with a brushed aluminum finish I want to be able to see the welds and have the contrast when you open the hood of the aluminum vs. the gold...errr final color
altitude411
Mar 4 2015, 06:01 PM
balljoint
Mar 4 2015, 06:18 PM
QUOTE(Cairo94507 @ Mar 4 2015, 06:55 PM)
Mar 4 2015, 07:31 PM
Mine will be red - of course. Maybe.
rgalla9146
Mar 4 2015, 08:10 PM
What oil cooler is going under that duct ?
Mar 4 2015, 08:28 PM
I'm doing something like this with fans. I'm not sure Cairo will need as much oil cooling as me since he is using an on engine oil cooler. Mine will only be cooled from the front and a block off plate used on the engine.
scotty b
Mar 4 2015, 09:20 PM
QUOTE(mepstein @ Mar 4 2015, 05:31 PM)
black
Does the metal shrink/pull proportionally with the depth of the channel?the bead roller more or less pinches the sheet and stretches it into shape. Thus thinning it ever so slightly. The external dimensions change little if at all. It is best to cut everything a bit over size, then trim to fit once the beads and bends are done
Socalandy
Mar 4 2015, 10:47 PM
QUOTE(mepstein @ Mar 4 2015, 06:28 PM)
Same cooler I went with and its perfect!!!
Mar 4 2015, 10:55 PM
QUOTE(Socalandy @ Mar 4 2015, 11:47 PM)
Can you squeeze a fan(s) in the shroud?
Socalandy
Mar 4 2015, 11:04 PM
I'm sure you can but I've driving in 100+ temps and the needle is rock solid at 180
Mar 4 2015, 11:22 PM
QUOTE(Socalandy @ Mar 5 2015, 12:04 AM)
I don't have an on engine cooler so i have to make sure the front cooler will cool. It's not the driving that concerns me, its the stop and go/traffic jams that are my concern.
Socalandy
Mar 5 2015, 12:24 AM
Here's a picture for you. I think you have room in front or in back of the cooler with the right size fan
Mar 5 2015, 06:21 AM
Thanks
rgalla9146
Mar 5 2015, 06:46 AM
I'm going with a copy of an original cooler. All metric plumbing front to back with a 911 thermostat under the engine shelf on the drivers side.
I also want to copy the metal cooler shroud like Scotty is doing.
Anyone willing to loan a fiberglass cover that I can use as a guide ?
Sorry for the hijack.
Mar 5 2015, 07:15 AM
QUOTE(rgalla9146 @ Mar 5 2015, 07:46 AM)
I'm pretty sure scotty is using my fiberglass shroud as a template. If so, your welcome to use it when he's finished. Hershey? Or maybe he will make a larger run of them if demand is there and a price could be worked out?
scotty b
Mar 16 2015, 12:48 PM
went to a friends shop last week before I headed south and punched some louvers. One for Michael, one for Mark
MDG
Mar 16 2015, 01:34 PM
Cool!. Thanks, Scott! Jeez, I didn't even ask for this. Can you paint mine in off-Irish Green?
Thanks again,
Michael.
Cairo94507
Mar 16 2015, 02:46 PM
Loving that! Can't wait to see that panel welded in and the cooler system completely mocked up. Thanks for the picture.
scotty b
Apr 1 2015, 04:51 PM
Bent some brackets, cut some holes, laid some pipe
and cut a really big hole
scotty b
Apr 1 2015, 04:58 PM
Tore down the engine and delivered to the builder
bigkensteele
Apr 1 2015, 05:04 PM
QUOTE(scotty b @ Apr 1 2015, 02:58 PM)
Scotty, who is the builder, and are those wheels in the second photo 911 spare rims? If so, what width? Look like they could be "7s, which I didn't know they made.
scotty b
Apr 1 2015, 05:07 PM
The wheels are Mercedes.
I'm not sure if the builder wants his info out there. He's an older guy that is retired now and still does occasional side work
Cairo94507
Apr 1 2015, 05:57 PM
Wow! That is a big freakin' hole you cut in my trunk.
Anyway, what has got to be has got to be. Can't wait to see the new panel welded in the floor and the reminder of the oil cooler fab-work done. I know for sure where the oil lines turn into the trunk Scotty will make a nice piece to cover and protect them. (BTW, thank you Jeff for the beautiful lines)
The engine is coming along nicely. I expect that to be back with Scotty by the end of the month. Doing a complete rebuild, all new bearings, rings, replacing the pistons and cylinders (staying 3.2) using the 964 cams and the heads are getting new guides, valves, etc. I expect the engine will be perfect. I really like the guy doing the work - he has over 30 years building Porsche engines and definitely knows his stuff (Thanks Scotty for the hook-up).
Mike Bellis
Apr 1 2015, 07:47 PM
This car is going to be so nice, Michael will never drive it...
Cairo94507
Apr 1 2015, 09:41 PM
No no no! I am seriously planning to drive this as my around town car. I want to enjoy it and cruise it around.
billh1963
Apr 2 2015, 06:34 AM
QUOTE(Cairo94507 @ Apr 1 2015, 07:57 PM)
You really think the engine will get done in a month? I would think that getting the machine work done would take that long. It will be awesome of it happens that fast!
bulitt
Apr 2 2015, 06:44 AM
Are you/do you need to use rubber isolators on the cooler mounts?
Apr 2 2015, 07:07 AM
QUOTE(scotty b @ Mar 16 2015, 02:48 PM)
I like it. 33% more louvers than the pms parts.
Cairo94507
Apr 2 2015, 07:10 AM
Yes. I am sure Scotty plans to use rubber isolators on the mounts. Thanks for mentioning that though.
Cairo94507
Apr 2 2015, 07:12 AM
Bill- the engine parts are already at the machine shop. My understanding is we will have them back fairly soon.
billh1963
Apr 2 2015, 08:28 AM
QUOTE(Cairo94507 @ Apr 2 2015, 09:12 AM)
Excellent! That is fast. I just assumed (from reading other people's engine rebuild experiences) that it would take a month to get the parts back from the machine shop. A 3.2L in that car should be awesome!
Cairo94507
Apr 2 2015, 08:34 AM
You know I was expecting the engine to take a few months too. However this builder has a machine shop he uses regularly and they apparently jump on his work ASAP. As soon as the heads arrived they jumped on them. I can't wait to get the report re the crank and rods, etc. The builder said they looked perfect but were still going to get inspected, polished, etc. I really am looking forward to seeing the engine assembled and ready to install.
I think this build is going to really come together now.
Apr 2 2015, 02:32 PM
QUOTE(Cairo94507 @ Apr 2 2015, 10:34 AM)
Engine builder, mr. x, often drives up here to test his engines on his friends engine stand so maybe I'll see it run before you.
Cairo94507
Apr 2 2015, 02:45 PM
I'm totally fine with that. I would love for them to bench run it before it goes into he car.
bigkensteele
Apr 2 2015, 04:43 PM
Can anyone at least reveal where mr. x has his machine work done? I am not looking for a builder, just a competent east coast machine shop.
Cairo94507
Apr 2 2015, 06:09 PM
Once I get the invoice I will let you know who did the machine work. Remind me if I forget....
bigkensteele
Apr 2 2015, 06:11 PM
QUOTE(Cairo94507 @ Apr 2 2015, 04:09 PM)
Thanks!
Cairo94507
Apr 4 2015, 07:57 AM
Just a few engine pics - nothing to see here really. Oh, these 911 headers might be available if someone is interested.....
Engine
Click to view attachmentCrank
Click to view attachmentHeads as they begin work
scotty b
Apr 4 2015, 09:07 AM
umm we already made a deal on those headers
Cairo94507
Apr 4 2015, 04:05 PM
OOOPPPS. Forget it guys, the headers belong to Scotty. My bad!
At what point is it fair to claim old age?
balljoint
Apr 4 2015, 04:41 PM
Scotty can claim old age.
He is really really old.
Kinda sad how old he is.
Are you sure he's 'memberin' right?
balljoint
Oh, and Eric says he is fat.
balljoint
Apr 4 2015, 04:42 PM
To be clear, Eric Shea said that scotty b is fat.
Cairo94507
Apr 10 2015, 04:20 PM
All of the machine work is completed - the heads are all assembled. All of the parts have arrived and this weekend the engine assembly will begin:
Click to view attachmentClick to view attachment Click to view attachmentClick to view attachment
