Kansas 914
Mar 22 2016, 02:06 PM
QUOTE(MoveQik @ Mar 22 2016, 01:59 PM)
I feel your pain Rick. I just sat down and put together my list as well....
Well - my list just got shorter.......
brant
Mar 22 2016, 02:34 PM
I'm jealous...
(well not jealous of Rick's list)
I just reinstalled the motor, trans, axles-starter-exhaust, fresh air box, gas tank, pump, wiper linkage, dash, stereo, speakers, etc....
crawled in last night and it turns over
no fuel - no starting....
even though every inch of fuel line was replaced... the pump energizes but nothing comes out...
oh well
now If it will run, then I only have to pull both door panels, pull the rest of the interior, re-glue the back glass, and readjust the side glass...
etc...
etc....
etc...
running out of time on my list
Sleepin
Mar 22 2016, 03:01 PM
StratPlayer
My car is getting ready to have a new dash installed along with the front vinyl.
That's it,,, car is ready....
AZ914
Mar 22 2016, 03:14 PM
QUOTE(Sleepin @ Mar 22 2016, 02:01 PM)
Dude,
A vasectomy only takes like 1 day to recover.
Sleepin
Mar 22 2016, 03:32 PM
QUOTE(AZ914 @ Mar 22 2016, 03:14 PM)
Dude,
I wish!
euro911
Mar 22 2016, 04:02 PM
#4 ... make sure to bring enough for everyone
Kansas 914
Mar 22 2016, 04:08 PM
QUOTE(brant @ Mar 22 2016, 02:34 PM)
You did put gas n the tank right?
JRust
Mar 22 2016, 04:41 PM
QUOTE(Kansas 914 @ Mar 22 2016, 03:08 PM)
Lines reversed???
Elliot Cannon
Mar 22 2016, 05:15 PM
QUOTE(brant @ Mar 22 2016, 01:34 PM)
I'm jealous...
oh well
etc...
etc....
etc...
https://www.youtube.com/watch?v=G-tCIRJH9p0
Kansas 914
Mar 22 2016, 06:42 PM
QUOTE(Elliot Cannon @ Mar 22 2016, 05:15 PM)
I actually "Laughed Out Loud"......
Sleepin
Mar 22 2016, 07:28 PM
'Twas a good one Elliot!
brant
Mar 22 2016, 09:52 PM
Ok. Has anyone seen a djet pump energize but not pump?
I've got plenty of flow in (s)... But nothing out (d)
Pump hums and I believe is spinning
I will drain the tank again and pull it tomorrow, to look for an internal blockage?
TravisNeff
Mar 22 2016, 10:44 PM
kinked a hose? your description sounds as dirty as it gets.:0
TravisNeff
Mar 22 2016, 11:10 PM
blow out the lines with compressed air to get rid of the Jello?
Check fuel pressure at one rail, then the other?
Elliot Cannon
Mar 22 2016, 11:12 PM
Air bubbles? Prime the pump? Hell, I don't know, I'm just throwing stuff out there.
TravisNeff
Mar 22 2016, 11:15 PM
Perhaps he should install some sort of kick start mechanism to get the pump runnin'
Elliot Cannon
Mar 22 2016, 11:20 PM
Tap it with a hammer? A small hammer.
TravisNeff
Mar 22 2016, 11:22 PM
Maybe the motto when I was younger, if you can't getter whet. then use a 5 gallon water bottle and a foot pump, chanchunka chunka whoosh!
Sleepin
Mar 22 2016, 11:27 PM
QUOTE(Travis Neff @ Mar 22 2016, 11:15 PM)
Funny you should say that Trevor. A couple years ago in Durango, I had a pump in the 1.8 that was failing. It would hum and not pump. However, if I hooked jumper cables up to it directly from the battery (funny with front trunk mount pump) it would pump great. Just a sign of the pump getting weak I guess. Not enough voltage would travel through the circuit to run the pump. With the jumper cables, hooked to the pump, it would get a full 12 volts which was enough to get me going for a little bit.
Not sure that is your issue Brnat, but you may check that.
TravisNeff
Mar 22 2016, 11:29 PM
hmm a hitch in your giddyup!?! we all suspected..
TravisNeff
Mar 22 2016, 11:33 PM
Pump in the front, energized by the relay board in the back is a long way. Perhaps the 80s car convert man may have sumfin'.
worn
Mar 23 2016, 10:57 AM
QUOTE(brant @ Mar 22 2016, 07:52 PM)
You know that sounds like the pump oughta be pretty bloated by now if that be the case. Gas oughta be going somewheres. I suppose it is one of the funny triple inlet outlet jobs with internal flow?
Kansas 914
Mar 23 2016, 11:25 AM
QUOTE(worn @ Mar 23 2016, 10:57 AM)
I would double check the lines - but you have been doing this a long time:
Mar 24 2016, 07:21 AM
T minus 5 weeks and counting.
Kansas 914
Mar 24 2016, 07:47 AM
QUOTE(76-914 @ Mar 24 2016, 07:21 AM)
I better get busy...
Wait I just remembered all I have to do is drink Wills' beer!
Sleepin
Mar 24 2016, 08:12 AM
All my plans just got
to
, so I will not be able to make it this time.
Kansas 914
Mar 24 2016, 08:42 AM
QUOTE(Sleepin @ Mar 24 2016, 08:12 AM)
to
I have to think it is a scheduling conflict?
worn
Mar 24 2016, 09:17 AM
QUOTE(Kansas 914 @ Mar 24 2016, 05:47 AM)
I would like to do a test drive but they are still putting salt on the roads. Maybe next week. Not even started my list.
Sleepin
Mar 24 2016, 09:43 AM
QUOTE(Kansas 914 @ Mar 24 2016, 08:42 AM)
to
Nope, work. The slow down hit home.
Kansas 914
Mar 24 2016, 09:44 AM
QUOTE(Sleepin @ Mar 24 2016, 09:43 AM)
to
Oh shit..
euro911
Mar 24 2016, 02:53 PM
QUOTE(Sleepin @ Mar 24 2016, 08:43 AM)
76-914
Mar 25 2016, 06:43 PM
76-914
Mar 25 2016, 06:44 PM
worn
Mar 25 2016, 07:50 PM
QUOTE(worn @ Mar 24 2016, 07:17 AM)
Drove out to look at the cars today. It was crystal clear after an ice storm. All the trees like diamonds.
Then I recalled that my list includes rebuilding front air dam. Oh well.
Chris914n6
Mar 25 2016, 09:54 PM
Removed the tools from the floorboard and installed the pass seat.
The new jumpbox didn't want to work today, so the only electrical I got done was installing a switch for the shop lights.
Decided to install the matching frunk lock, but the rad shroud got in the way so blew the rest of the evening looking for the matching door handles etc. Found half. Did get the door latches out and cleaned, as they were gummed up.
Any progress is good.
VegasRacer
Mar 28 2016, 12:19 AM
This Thursday, the 31st, is the Last Day to order a shirt.
914_teener
Mar 28 2016, 09:20 AM
QUOTE(76-914 @ Mar 25 2016, 05:44 PM)
Kent....you left out the Mcdonalds.
Justinp71
Mar 28 2016, 09:24 AM
Man I would love to go to this! But got to many commitments... Someday hopefully.
Steve
Mar 28 2016, 11:46 AM
I'm trying to get the days off work. I should know by tomorrow.
SharonG
Mar 28 2016, 12:21 PM
to
jim_hoyland
Mar 28 2016, 05:06 PM
QUOTE(Steve @ Mar 28 2016, 10:46 AM)
Do it ! We will have a great caravan and your car will thank you for getting out on the road
76-914
Mar 28 2016, 06:47 PM
QUOTE(914_teener @ Mar 28 2016, 08:20 AM)
Haha. Good one. The guy in the pic was just told they are eating at Mac's.
MoveQik
Mar 29 2016, 08:49 PM
Awards are all done. Categories are tough:
Best Lexus Yellow 914
Best 3.2 conversion with pulled fenders
Best 914 with no cowl vents
Best 914 driven from Cactus Road and the 101 freeway in Arizona
Best 914 owned by a guy named Mike Wills
Best 914 owned by a guy that brought beer for Mike Moorman to drink
brant
Mar 29 2016, 10:06 PM
There isn't a golden jack plug award?
Kansas 914
Mar 30 2016, 08:43 AM
QUOTE(MoveQik @ Mar 29 2016, 08:49 PM)
Voting will be tough this year...........
Kansas 914
Mar 30 2016, 08:44 AM
QUOTE(brant @ Mar 29 2016, 10:06 PM)
The winner is a forgone conclusion so.....
Steve
Mar 31 2016, 08:36 AM
Bump
Steve
Mar 31 2016, 12:51 PM
QUOTE(VegasRacer @ Mar 27 2016, 11:19 PM)
I will take a large shirt!!
914_teener
Mar 31 2016, 01:09 PM
One large please Juan.....
Will you be able to bring it to the Festivus of Speed?
