I'm glad this part is behind me. I had that thing in and out 50 times. Anywho, this is what I came up with. Let me clarify I; Bigcat suggested the radiator and fan set up. I just put em together. It's an Intrepid fan/s unit and Sirocco radiator. The fan set up is defective and was used as a mock up while a new one is shipped. The 2 are < $150 combined with shipping.
Here is the radiator/fan in it's removable frame.
A look at the radiator to frame attach point. There are two per side. and yes those are cheese head screws.
A side view of the same shot. That is a faucet washer compressed between the rad post and the frame.
The square 1" legs of the frame will sit over these posts
And the smaller round legs will sit atop these
The square receiver end gets a rubber cushion
With this slightly massage washer to protect the rubber from wearing against the post.
Then the unit is set and held in place by these hitch pins. For future access I will be able to remove all the radiator, shroud, etc. < 10 min's.
And in place
