I've got around 250 miles on Kugel now and thought I'd share some of my teething problems up to this point. Somewhere around test drive #5, I had settled down enough to realize that it was
hot in the cabin. Not only that but my gas tank had become a heat sink as well. The first thing was to seal the gap where the "old heat tube" passed thru the bulkhead. This required a couple of crescent shaped pieces of foam.
Click to view attachmentTest drive #6 revealed no noticeable improvement. I forgot to seal off the air box so I made a couple of foam plugs.
Click to view attachmentTest drive #7 showed a big improvement but found the "full" gas tank was still hot to the touch after a run. I had one of Mark's cowl seals on my shopping list because mine was toast but I thought I would try something different instead. After all, should I expect a new seal to perform way outside the envelope for which it was developed. The OG seal had 5ea / 45mm for an area of 1590mm)openings (if any) opening into the front trunk. And I had added 4 38mm holes or 1134sq mm. So this was my solution. I took apiece of 1/2" walled pipe insulation and placed it over the existing old damaged seal. As you can see in the pic's it comes with a slit in it so it slides right over the old one. The first nite it was a tight fit and raised the hood very slightly. By the 3rd day the insulation had compressed into place and the hood now sits as it should. Noticed the compressed area on the insulation?
Click to view attachmentClick to view attachmentClick to view attachmentThis was the final fix and I'm happy with how cool the cabin is since these changes. But I still had a nagging overheating problem. I had been warned not to run thru the longs by a few members so I'm hoping it isn't the additional length of hose that is the problem. I choose a 14 mile round trip to begin testing. OAT range from 88F to 95F. 7F is a small difference. The next 3 test runs consisted of attaching a small lip to the bottom of the fender opening to act as a scoop; enlarging the opening in the fiberglass fairing 1/2" across the bottom; removing one access plug in the floor and running with the front hood partially open or cracked. None of these attempts helped. I was able to find the temps would always begin their ascent at 9 miles nom. With the IR I found I had a 5F drop across the radiator. Hold'er Newt. That ain't right. With fans on high, low or off didn't matter. Unless the cover for the radiator was removed. And then the fans cooled it quickly. So now I can assume the radiator is sized correctly, thermostat good, hose runs good, fans good, etc. How could this be. I assumed because others had success with the OEM oil cooler openings (along with 4 more punched out) that this should work for me as well. But I was comparing apples to oranges. My radiator, fans, and venting were different as well.
I didn't think it would make any difference but I decided to cut out the area that had the punched holes before I called Bob to explain what a dumb ass I am. The overall cut out was only 3.25" x 18" or the same as the area cut out on the bumper and fairing. Here is a pic of the removed piece.
Click to view attachmentNot much larger but after "now" Test drive #15 I had my first result. I completed the test run and temps were in the middle. Checked a few items and went back out. After 6 miles the temps began to rise but leveled off towards the high end of the scale. It was 82F that run. The coolest so far but still not much difference in ambient temps.
Then I spotted it. What an idiot! All I can say is that I missed this one and have no excuses.
Click to view attachmentClick to view attachmentI had not considered the gap between the fender/fairing and the body. The gap along the bottom is appx 1/2", you can see the pie shaped openings on the sides and the one along the top edge was 1.5"-2". After a quick duct taping we went on
Test drive #16. Holy
, that was it. Duh! That incoming compressed air had been shooting thru the gaps. The gaps were probably low pressure areas and diverted most of that incoming air right out the fender. I have been running w/o fans for 2 days without any temps above the 1/2 way mark.
Tonite I removed the tape and filled the gaps with foam. The gap was so large along the top that I stuffed an untrimmed piece of pipe insulation in there to seal it. I have a few cosmetic items and other things to do but other than that, I think this might be the final chapter. I hope some of this build thread will help others with there conversion somewhere.
