After getting the jam seams welded I moved on to installing the rocker end cap we fabricated some time ago. This car had quite a bit of rust repair in the inner fender/hinge post area when we made the car road worthy many years ago. Some good, some bad.
I'm just working on it being functional. If I run into this on another car. The fender will have to come off and be refitted.
Click to view attachmentClick to view attachmentClick to view attachmentNow that I look at the bottom of that left front fender I may decide to cut that out and recreate it.
But I need to keep reminding myself this is going to be a daily driver.As these cars continue to go up in value and the front fender is
welded on. Maybe RD will look at making a patch panel for this area. I
think there's one for both the 911 and the 356. I'll look and see what the one looks like on the
donor on Monday.
We cut the rocker cover channel off because it was so rotten when we took apart the car. Either way it will have to be recreated. Looks like in our first go around we did some welding and took correct shape out of the bottom edge of the fender. It kind nof rolls down and it isn't attached to the inner support.
Click to view attachmentWhen the time comes both sides will get some VERY detailed seam sealing, both tube and spray on. Then they'll get undercoated. Then on top of that they get Mark's inner fender liners to keep the debri from getting up there in the first place.
I did test fit the rocker cover.
