Thursday Jan. 26th.
Super In Laws out it the other room engineering the rotisserie mount for Taylor's project.
Matt from 914 Rubber called and asked if I could squeeze out the front control arms he'd dropped off some time ago. With the lack of time and space I'd put off a couple project requests from him. So figured it was the least I could do.
Nothing complicated. Just bring them back to life.
Click to view attachmentLearned a couple things. #1. The control arms
barely fit it my blasting cabinet.
#2. My shop press is too small for the back end of the control arm. #3. I need to purchase the next size bearing splitter/separator when I get a larger press.
Front ends pressed out. Back ends got lit on fire.
Which kind of stinks the place up.
The flanges needed a little TLC.
Click to view attachmentClick to view attachmentCalled texted Matt and had him order a set of ER OEM rubber bushing. I'll also need at least one ball joint. Looks like one strut was cut off with a Sawzall.
I should add this is a set of control arms Matt bought off the internet to replace his that had gotten bent. So maybe we can pull the other ball joint off the old control arms. Or replace both while we have it torn apart. His call. I ordered a Porsche ball joint socket when I got home.
I'd always just borrowed it from Jeff.Click to view attachmentClick to view attachmentTaking the control arms to RS to pull off the ball joints so I can finish up the paint job.
