cary
Feb 22 2016, 10:03 PM
On to installing the left side window frame patch. I started with giving the patch and frame a shot of weld thru primer. Then punched the rosette holes on the frame side.
Click to view attachmentGave it one tack so I could start the final fittings.
Click to view attachmentAfter cutting the patch to cowl seam again with Dremel. I tacked it in another couple spots.
Click to view attachmentHere it is all welded in.
Click to view attachmentAfter grinding.
Click to view attachmentAfter a shot of self etching primer.
Click to view attachmentIt's going to take a little All Metal filler in a couple low spots (arrows). I refrained from over grinding, over working the metal and using the MIG as a glue gun to fill in the low spots.
cary
Feb 24 2016, 12:39 AM
Had the torch out so I needed to reinstall the guide tube for the front trunk cable.
The tube is steel, not brass or copper. So I had to stop at NAPA and pick up six inches of 5/16 brake line.
Click to view attachmentClick to view attachmentClick to view attachmentI'll add a shot of final brazing.
cary
Feb 24 2016, 12:44 AM
We'll take a time out for a while to do some work on Mark Whitesell's (914Rubber) project car.
veekry9
Feb 24 2016, 06:50 AM
Nice work,a common corrosion area,the why of pulling the glass.
76-914
Feb 24 2016, 11:19 AM
I'm going to Hate it when you go back to work.
You should "rent-out Super-in-law"!
cary
Feb 25 2016, 12:18 AM
The job posting that I've been waiting for was posted today .............
Feb 25 2016, 06:07 AM
QUOTE(cary @ Feb 25 2016, 01:18 AM)
If they have any doubt about your ability to focus on a task, just show them this thread.
cary
Feb 25 2016, 08:59 AM
I found out yesterday that the position had to be approved by the CEO before it could be posted.
Got that covered. The gentlemen that I'll be working for has seen me in action many times. Now its just politics .............
cary
Mar 1 2016, 07:33 AM
Paint for the frame bench was on sale at the horsey supply store.
Click to view attachment$20 ...............
cracks me up. I used many gallons in Montana restoring balers, bale wagons, hay rakes and my much missed/loved International tractors.
Bench will be Kubota Orange
Fixturing Ford Blue.
cary
Mar 7 2016, 09:40 PM
QUOTE(cary @ Feb 25 2016, 06:59 AM)
Interview on Thursday AM.
Cairo94507
Mar 7 2016, 09:51 PM
Best of luck.
cary
Mar 10 2016, 12:23 AM
While I'm working on Mark's car Super In Law has been busy.
Starting the restoration of the pinch weld frame for the frame bench.
Click to view attachmentToday he built an extension for the welding cart that has the plasma cutter on it.
That way its tall enough to be used on the parts car that's on stilts.
Which gave us room to put the torch on the same cart.
cary
Mar 10 2016, 02:36 PM
QUOTE(Cairo94507 @ Mar 7 2016, 07:51 PM)
Best of luck.
Interview went great. Only issue was, it was for the second job that I applied for. Applied on Saturday, called for interview on Monday, interviewed on Thursday. Whoa ...
Pretty certain I could have that job if I wanted.
Didn't pay enoughThe other jobs interview was brought up by them 3 times at the end of the interview.
Two positives that came out of it. 1. The person that will be my new boss walked by 3 times in the 12 minutes I was sitting in the lobby.
I'm sure the place was a buss after I left. 2. Had a good hour interview that included the HR director. She now as a handle on who I am and what I'm all about.
I think I'm caught up in a due diligence exercise. For one, the Director that thru my hat in the ring is a long time friend. The person that will be new boss has become a friend. I'm also thinking the delay might be a budget balancing issue.
raynekat
Mar 12 2016, 01:50 AM
QUOTE(cary @ Mar 10 2016, 12:36 PM)
Sorry it didn't work out for you man....
5555555 (hahahahaha)
cary
Mar 26 2016, 08:01 PM
While I'm working on Mark's car, Super In Law stripped the front and rear suspension off the parts car. Now we'll decide what we'll cut it and keep and what will get
shredded and melted.Click to view attachment
cary
Mar 30 2016, 10:03 PM
Weather broke so we took a break from Mark's car and got after prepping and painting my frame bench.
Super In Law has been refurbishing the pinch weld frame and its now ready for some paint. We start with another once over with the wire cup brush.
Click to view attachmentTape off all the decals ........
Click to view attachmentFinished product ...............
Click to view attachmentWhile I had the Ford blue in the gun I painted the templates that will be saved. I paint them to save myself from myself.
I'd forget why I cut them out and they'd end up in the scrap barrel.Click to view attachment
cary
Mar 30 2016, 10:19 PM
Then on to the bench itself .......... We start with wire brushing the cross members.
Click to view attachmentThen I shoot some of the bright Kubota orange.
Click to view attachmentThen we convert the open trailer into a paint station. Super In Law got busy with the wire cup brush. Then I jumped in with the DA with 40 grit. The DA made short work of it.
Click to view attachmentTurned out great. Gave me some good painting practice.
Distance from the surface and speed of my fan movement.Click to view attachment
76-914
Mar 31 2016, 08:03 AM
cary
Mar 31 2016, 08:32 PM
Took the day off, but we went and got a refill for our #2 Argon/Co tank. While at Newberg Steel Super In Law bought me an early and expensive birthday present.
Jet Horizontal/Vertical Bandsaw.
Click to view attachmentThis should make the precision cuts we'll need when we create the fixtures for the frame bench.
My 18" welding clamps that I bought for future trunk installs arrived from ZORO.
Click to view attachmentThen we rolled the frame bench off the trailer.
Click to view attachmentTomorrow morning will start with some shop clean up and reorganization before I start on Mark's wheelhouse rust ..............
cary
Apr 1 2016, 10:17 PM
Between the shop clean up and the landlords 4 wheeler coming to a dead stop I didn't get to get back to Mark's car.
Here's a few shots after I got everything tidied up. The rotisserie will slide 1/2 way over the frame bench when it's up against the wall when not in use.
Click to view attachmentClick to view attachmentClick to view attachmentWe decided that we'd paint up three of the channel irons that came with the bench. We'll use two of them to hold up the pinch weld frame.
cary
Apr 2 2016, 08:11 AM
For those that have been reading along it looks like the job that I'd thought I'd be taking has been cancelled. Best I can tell Albertsons buying Haggen was the final straw. Worst part is, two of the folks that work there are my friends. They're really embarrassed.
So time to move on. The plan was to restore 2-3 cars a year after I retire. Now maybe we'll reverse that. Find a job that will work around restoring cars.
cary
Apr 8 2016, 08:24 PM
Next week will be spent building 3 or 4 fixture pieces for the frame bench.
I moved Mark's car to the frame bench this afternoon. My pinch weld fixture won't work for most of the work I'll be doing. i.e. Right long and hell hole.The fixture is in the way. So we'll be building the transmission mount and right suspension mount fixtures. Perhaps the pinch weld stands also.
On the employment front. Next week will be busy. Two automotive related interviews. Both of these deal with Porsche and restoration. The other is a job shadowing day. Then the company mentioned above will have another opening in the near future. One of the salesman died in motorcycle accident last weekend. Kind of sad. I've known him for 25 years.
Luke M
Apr 9 2016, 11:25 AM
Hi,
Would you happen to have any info on your pinch fixture ( manufacture, model # )?
I need to purchase or make one for my car.
Thanks,
cary
Apr 9 2016, 05:01 PM
Here you go ..............
Blackhawk Quadri-Clamp 97150
Luke M
Apr 9 2016, 05:28 PM
QUOTE(cary @ Apr 9 2016, 04:01 PM)
Click to view attachmentThank you sir..
cary
Apr 13 2016, 08:34 AM
Here's the first fixture piece we're building. The long jack stands.
Click to view attachmentOur first version will be solid. We'll always set the car on the stands with the lift.
Version #2 will be more like the Celette. Tube in a tube.
I'm leaving them a bit tall so they can be cut down when the time comes to create the tube in tube.
Not really a pinch weld clamp. You pinch the entire car between 3/8" rails on top of the stands. We'll add gussets as we progress. Car is pretty light with no engine and transmission.
Click to view attachmentToday's design work .............
cary
Apr 15 2016, 07:29 PM
My brain hurts. I haven't done that much measuring and geometry in a long time.
With the girders not being perfectly formed. It took a few hours to get things squared up. Now on to the suspension and tranny mount supports.
cary
Apr 18 2016, 09:39 PM
Here's the design I came up with after I cut the tubes an inch too short.
I couldn't get a 10mm bolt long enough to replicate the Celette. Going from the bottom thru the spacer and the two plates.
Click to view attachmentHere's the finished product all painted up.
Click to view attachmentSuper In Law started the left side. We figured we might as well get it done while it was fresh in our mind. It will be created in the Version 2 style.
As soon as he gets finished I'll flip around the right side fixture and get back to work.
Like this picture of the Celette.
cary
Apr 19 2016, 10:56 PM
Super In Law jumped on the left side.
Locating .............
Click to view attachmentHe comes up with some of the damnedest contraptions.
Click to view attachmentSo he could weld the pipes to the base plate.Finished the paint job just as we were leaving ...........
raynekat
Apr 20 2016, 12:40 AM
Definitely....a couple of mad scientists hard at work.
ps Back in PDX now.
cary
Apr 20 2016, 10:19 PM
Here they are in the locked down position ..............
Click to view attachmentClick to view attachmentNow moved into the wheelhouse/long repair position ,,,,,,,,,,,,,,
cary
Apr 22 2016, 10:22 AM
Tool Whore Note:
I've used the same Norsemen 1/8" jobber length drill bit for a week.
Placed my first order with MSC for some Rotacut spot weld cutters. Got here in one day from their Nevada warehouse. I think this will be my go to supplier for consumables. Looks like they carry metric hardware. I'll have to compare pricing with McMasterCarr
mb911
Apr 22 2016, 11:20 AM
Great work.. I enjoy the updates. I don't get near as much time in my shop but I am off for the next month so hopefully I can get some updates like you.. Great fixtures as well..
cary
Apr 28 2016, 07:57 AM
Looks like the 8-5 job that I'd been waiting for has been postponed. If and when it does come up it will probably be located in Seattle. Wasn't meant to be ........ time to move on.
I guess I'll be playing with Porsche's. The preferred shop is about 2 miles from the house. 7 minutes by car, 10-12 by bike. We've already discussed three ten hour days at his shop and 2-3 days at my shop getting and putting 914's on the road. This a Porsche only operation.
The other shop has 2 early 911's and a 356 coming back from paint that need to be assembled.
I hope to put something together so I can start the Monday after WCR.
Short Tool Whore note :
Taking delivery of a Challenger Low Rise lift tonight. Cheap.
Needs a hose and a new oil tank. Kind of rolling the dice. But we've had pretty good luck fixing stuff.
cary
Apr 28 2016, 09:44 PM
Low rise lift was delivered ............
Click to view attachmentBasically the same as putting the car up on jackstands. But a lot faster.
cary
May 15 2016, 08:16 PM
Super In Law got the low rise lift up and running .............
$560 after parts and fluid.
JoeDees
May 19 2016, 08:20 PM
Many pages/posts ago you mentioned using the undercoating gun with tube to spray the heavy duty anti rust paint stuff way up into the targa bar... if you don't mind me asking, how'd you access the area to get it waaaay up in there?
cary
May 25 2016, 07:17 PM
QUOTE(cary @ Apr 28 2016, 06:57 AM)
Sabbatical will be over in two weeks.
I'll be going to work at the above described facility in two weeks.
I'll give it a name after I actually start working.Life is about to get real busy .............
I'll be picking up Doug's (raynekat) 914-6 conversion in two weeks.
Time to put the pedal to the metal.
mbseto
May 26 2016, 07:26 AM
I'm starting to suspect you only married your wife because of her dad.
cary
May 26 2016, 08:27 AM
It would seem that way. But no. He was a Federal Highway project engineer and I really didn't get to know him the first 10 years we were married. He was always working out of town. But thru the years we've become best friends. I'm kind of dreading every year that passes by.
mbseto
May 27 2016, 11:29 AM
It sounds like you guys are enjoying every year that passes by. Finding a good shop buddy is a rare thing, I'm a little jealous.
And by the way, I really appreciate the time you take to document your builds. I refer to your threads all the time.
altitude411
May 27 2016, 07:56 PM
Thanks for taking the time Cary. Making Montanan's proud
cary
May 28 2016, 10:03 AM
Your both
Welcome.I've always believed a picture is worth a 1000 words.
As for my writing skills, my brain moves a little too fast for my poor typing skills.
Mentally I've finished a paragraph, but I've only typed half a sentence.
Like I've said before. My primary goal is getting as many of our cars on the road as possible.
There just too much fun to drive ...............
Today will be some
me time. 1. Walk thru my tool needs at my new job. Meeting at 10am. 2. Oil change on 914 DD. Finally installing tuna can. 3. Start designing computer monitor hanger for my new to me 55 inch computer monitor in the shop. Mom and step dad are getting a new one. Only expense will be building hanger and the HDMI cord. 4. Maybe a little grinder and cold galvanizing in my DD trunk.
cary
May 30 2016, 10:10 PM
Operational Note :
The rotisserie slides easily over the low rise lift.
cary
May 31 2016, 10:53 PM
DD onto the new to me low rise lift.
Click to view attachmentI was out running around working on my new job tool box. Super In Law dug the
summer range forge out of the chicken house. He had it all refurbished by the time I made it to the shop.
This will be used to heat up the suspension tie together plates. Making then easier to form.Click to view attachmentComments from last year ..........
JoeDees
Jun 1 2016, 07:22 PM
Damn. I've been sweating making those for a while...
cary
Jun 3 2016, 09:15 AM
I'm starting the day with delivering my new tool box to my new place of employment.
My first
big boy tool box.
cary
Jun 7 2016, 08:13 PM
Picked up Doug's 914-6 project this am. We'll need to do some construction/redecorating. Super In Law is going to build a wooden super structure to store/house body parts as they come off cars.
Front Hood
Trunk
Engine Lid
Top
Bumpers
Valances
Doors
Rocker panels
etc.
Click to view attachmentHere's Doug's car upon arrival today.
Click to view attachmenthttp://www.914world.com/bbs2/index.php?sho...p;#entry2356501
cary
Jun 16 2016, 09:34 PM
Week #1 of the new job.
Day #1. Stripped a 80 SC Targa of all usable/sell-able parts.
Day #2. Begin conversion of a forward dated 69 911 caged race car that will become a 73 RS clone.
Day #3. Help with the preparation of 2 Cup cars that will be raced at Infineon this weekend. Then back to my conversion project.
Don't pinch me, I don't what to wake up from this dream.
cary
Jun 16 2016, 09:47 PM
Today was basically a shop tidy up day .....................
Got my new shop PC set up and running.
Click to view attachmentNow I can order parts from the shop. Windows 7 on the old clunker wasn't getting it done.
Then went back to hole that needed to be patched in my DD rear trunk.
Click to view attachmentTime to try out my birthday present. Miller MIG welding goggles. I bought them primarily for wheelhouse and floor pan welding. But I thought I'd give them a try.
Click to view attachmentVery impressive .....................
While I was working on the car. Super In Law started measuring up the flat work we'd like to do in front of the shop door.
Click to view attachmentSelf Etching Primer ............................
Click to view attachmentFirst layer of seam sealer ........................... Evercoat brushable
