Taking a day off from welding and grinding ..................
Mike (Warpig) stopped by for some help with his car. It has a major main seal oil leak.
Because of the leak, the cars has been sitting for around three years.
Getting these cars back on the road is my thing ................ 75 1.8L.
Click to view attachmentHere's the aftermath of the days work .............
Click to view attachmentClick to view attachmentClick to view attachmentAnd this is what we came for ................
Click to view attachmentWorklist :
Rear main seal
Clutch
Flywheel seal
Replace both harnesses with Jeff's fine creations.
Intake runner tubes
Intake manifold gaskets
Fresh fuel and vacuum hoses
Valve adjustment
Powder coat tin (Mike)
Soda blast fan housing (Cary @ Rothsport)
Front main seal ..........because of the mess we found. Looking at the density of oil I'm thinking its primarily came from the oil filler seal. Thick and messy at the top.
914 Rubber oil vent/filler seal
Oil cooler seals
Fuel injector seals
Send fuel injectors out for service (send to GB)
Create missing pre heater tube (Mike)
Mike is looking into a muffler replacement
914 Rubber SS engine tin allen screws
Thermostat cable
Clutch cable
Speedo cable (?)
Flywheel Bolts
J Pipe heater hose engine tin grommets
(2) 8mm CV bolt plates
(8) 8mm CV bolts
Flywheel pilot bushing
Swepco tranny fluid
(2) triangle exhaust gaskets
Alternator cooling duct
Backup plug boot
Speedo drive o ring
Tranny ground strap
Engine compartment seal set
(2) engine to body heater hoses
Add timing marks to fan and flywheel - I saw one unpainted and a painted about 45 degrees around. I'll have to figure that out.
(2) Transmission output shaft seals
Tranny seal behind guide tube
Mike's taking the flywheel to a machine shop by his house to see if it can be turned. Looked to have enough meat.
Need to locate the flywheel turning info and the fan marking template to add to my Google Drive 914 info file.
Blue info added 11/13/16 am
We'll do a shopping list and parts sorting in the am. Then Mike will go to work on removing the rocker panels. Project will wait for the parts washer replacement motor which is on its way.
Sitting in a UPS trailer in Illinois.
