The back half of the trunk came off real easy. Then I decide to do it right, the muffler heat shield needs to come off. There's no way to get things cleaned up right with it in the way.
First thing to do is locate the spot welds.
Came off pretty easy. Next time I would use 3/8" spot weld cutter. The 1/4" I usually use was too small.
[[/quote]
On mine since i was replacing the rear trunk back section, I cut the heat shield standoffs out at the trunk side and left them attached to the heat shield.
On re-assembly, i used SS pop rivets to reattach
