Hello there from RS25. I was googling EG33 stuff and found your build! Very interesting!
If you need any wiring help, I can give you a little help and advice. I have an EG33 swapped impreza, and it's been running on the stock SVX Ecu for nearly a year now. I am swapping over to a megasquirt though, in preparation for a supercharger.
I saw earlier you were worried about the coolant temp sensor? Just a little heads up, the EG33 uses 2 temp sensors, located right next to eachother. The 2 wire sensor is for the ECU, and the single wire sensor is for the gauge cluster. If you know what the stock porsche sensor's resistance curve looks like, I know I've got the resistance curve for the subaru sensor around here somewhere to compare it to. Alternatively you could just replace the subaru cluster sensor with the porsche sensor, though you may have to make an adapter, or drill/tap the hole for a different size.
Also, I'd recommend hooking up the Check Engine Light to something. The OBD1 ECU allows you to pull CEL codes by connecting 2 wires (no external code scanner required!). It does this by flashing the CEL at you (it's kind of like morse code, long long short short short would be code 23, etc.) This can be MAJORLY helpful in troubleshooting (My ECU coolant temp sensor got damaged somehow when I was installing my motor, and it wouldn't fire without it! I wouldn't have been able to diagnose this without the flashing CEL telling me!).
The EGR system can be removed without any big fanfare. Just leave the solenoids connected to nothing and the ECU will be happy. Block off the hole in the header if you're using the stock subaru headers, and block off the opening on the intake manifold. I've gotten a CEL once from this, and it was because I gassed it immediately after filling up the fuel tank. No big deal.
The radiator is always a pain. Comes with the territory. Good luck on that! I can tell you though, that with my Griffin (think it's a 26"x13"x3"thick) double-pass radiator, my fans have never kicked on under normal conditions. It just doesn't get hot enough. I let it idle for 2 hours once just to test this (during the summer) and nothing. Soon as I unplugged the coolant temp sensor they kicked right on (so they were connected properly). I don't know if you've got room for that, but it works well for me. Part number: GRI-2-58190-X
Also, you probably want to replace the water pump. I've had several of them leak on me (the seal for the water pump shaft goes bad). When you do, use a stock subaru thermostat. The aftermarket thermostats tend to be junk and cause problems.
Here are a few of our build threads that may be of use to you:
http://www.rs25.com/forums/f145/t173252-bo...ie-dropper.htmlhttp://www.rs25.com/forums/f145/t71120-ric...-230-na-hp.htmlBest of luck to you on your build! I'll be following along!
(Also, whatever you do, make sure the IRIS system is functioning properly. Replace all the old and brittle vacuum lines under the manifold while you've got access. The IRIS system is responsible for ~30hp in the midrange, due to it's variable intake geometry)
PPS: Don't go to nasioc. They're pretty much the devil. I only go there for cheap parts and local guys. RS25 is much friendlier. Subaru-SVX is also a great forum with some dedicated fellows who will hate you for "Chopping up a perfectly good SVX"
