Hey George,
Kent is correct, my mount is from coldwater conversions.
It's a very good strong mount. I modified mine a bit because of a clearance issue with the headers. Need to do a bit of work on it in the next few days so I will post some pics of it installed. Just got it shimmed up to the perfect angle last week.
cradle link
You don't HAVE to use a cradle mount if you use a 901 trans, but I would go with one myself because the 3.3L engine is very front heavy and weights quite a bit more than the 4 cylinder engine @ ~350#. With a cradle mount the engine has some additional bracing front to back aside from just being attached to the trans, so your trans ears are under far less stress (reduces the "lever action" that Kent describes).
Other options: You could modify the smallcar mount that is used in Vanagon conversions and mount it to the stock engine bar like Amenson did.
Amenson mount link - mount is on page 1
The thing is that the smallcar mount is $359 for the 3.3 and then you have to modify it. The coldwater mount is $500..much stronger....bolts right in.
You could also do what Kent, Bob (BIGKAT_83) and others have done and that's fab a mount yourself. After seeing your skills on the resto of your car you could definitely handle it.
Give the Subie trans idea a while and you will probably change your mind.
BTW there are 3-4 SVX's up here for sale CHEEEAAAP. Craigslist.
