QUOTE(Chris H. @ Feb 17 2018, 01:31 PM)
After trying several methods, including drilling a small hole in it and using a "tee", welding a nut to it, etc., I finally coughed up $20 on this extractor and it came out easily.
Click to view attachmentI soaked it in PB Blaster for a week straight beforehand. That definitely helped.
Yep, that is the correct tool for the job. Welding on a rusted hardened steel stud over 30 years old would never be my first choice. And if it was It would be my last.
If you are going to use the welder as the tool of choice. I would cut them off closer to the base of the stud. If you have some threads there that is even better, put a nut on it, screw it down as far as it can go, but leave a bit of it for a valley. So nut sits a bit proud. I would then heat it with a small torch, burn off the crap. You can't weld dirt. You then take your MIG, I would prefer to use a TIG for this. And you go for the center of the stud, you get it nice and hot. And then work your way out. I would use flux core as it can handle a bit of crap in the weld if something cuts loose.
If doing this with a TIG, you preheat the stud, to fire red, with a torch. That will allow impurities to burn off. And then you can TIG clean metal. With the TIG you can get the tungsten down and start heating the stud before you get into the nut. You can then get them to almost fusion weld the nut to the stud, then you can work out and start adding filler. With this, you could then grind it and polish it up and make it look like a bolt.
You want to get heat all the way down the stud length, if you don't part of it will not be hardened. When you apply torque to the stud to try and remove it, it will stretch and snap right at the transition from soft to hardened metal. And you will be
I have also been know to take a impact socket, prep it up, and weld it to the stud.
BTW, if you want the best stud freer around. You take some acetone, and automatic transmission fluid, you mix it together, and you spray, brush, drip, soak, whatever the offending part. It works like a champ
Another thing I like to do is
the head of the offensive stuck part, that allows the stuff to migrate down into the opening a bit easier. I even have a hammer that fits in an air chisel for just such an offensive item.
