Don’t have any pics of this, but I did try flipping the intake…I’m not confident enough in my skills to do it this time. Too many variables if it doesn’t start once I get it done. When I flipped both the FI runner section and the top section there was interference with the AC unit. Found a company called Outlaw Engineering who will do a ¼” phenolic spacer for the SVX, but even with that it would still interfere. When I flipped just the top piece the fuel lines underneath didn’t cooperate. It can be done though, maybe version 2.0.
So on to the trans…mine is 2006 WRX unit, so it is a “turbo” trans (2.5T). Bought Ian’s kit to lock the diff and change to the older stub axle style. Ian is assembling a very concise set of photos to explain the process so I won’t outline all the steps since his will be better.
First, the when you take off the center diff, which is the tail section of the trans it’s not immediately obvious what to do next.
Just pull out this stuff:
Click to view attachmentThe center diff is worth between $150 and $300 depending on the year and how many people need it at the time you want to sell it.
Here's the diff lock installed:
Click to view attachmentTo get the nut off for the diff lock you need to take the next section of trans cover off. You'll probably need a new gasket or some gasket maker. Mine tore into several pieces. It's made of a paper-ish material.
New stubs in...ready to go.
Click to view attachmentTail end...the stock bolts are way too long for the cover. Shorter ones are provided in the kit.
Click to view attachmentSome "gotchas":
1. If you are installing stub axles be very careful with the axle seals. I bent one by slightly tapping it with a wrench. They should sit flush with the axle holes. I also pushed one in a bit too far but was able to get it out.
This is "way too far" in:
Click to view attachment Not quite German quality engineering we're dealing with so things don't all fit with a crisp snap like we are used to.
2. When you remove the middle section of the trans cover to get at the differential nut the gear selector shaft will just fall out onto the floor which is alarming. Don't worry, you did not break it.
