QUOTE(Chris H. @ Jun 25 2018, 04:33 PM)
The SVX rad is actually quite a bit taller than the Alpine rad. The Alpine is only 10" tall, whereas the SVX is about 15" tall and not quite as wide.
Regarding the chip, it's actually an earlier version of the ECUTune chip. Same map and also allows you to use 87 octane if you want. There is a switch that you install that retards the timing a bit in 87 octane mode...so...I won't be using it unless I do a long road trip or something. I actually bought the ECU with the chip installed from a guy who did a bunch of Vanagon conversions. Really smoothed things out.
Great Tip on the Alpine RAD, Ebay also has one listed that is a 56mm core thickness instead of the 40mm in your listing. Just in case you need a bit more cooling, in close to the same size.
Glad to hear the ECU Tune chip does the trick, stage one tune. That is, watched the videos on the turbo build with the EG and all the stuff he went thru to get it to run correctly with an MS unit.
Love to see this project continue to evolve and become more refined.
