BTW I will be re-taping the joints on the rad...had to remove the aluminum tape when I took the radiator out to seal up the threaded hole. Should be pretty air-tight.
The one odd issue I am having is that it seems like the thermostat is acting weird. I tapped the return line for the reservoir at the lowest point right at the water pump.
Should be drawing a nice vacuum there. The temp sensor is on the return line side and doesn't register at all for a long time, then shoots up pretty high all at once. The return line gets VERY HOT and the pump doesn't seem to run until the engine is pretty hot. The lines under the car are cold for quite a while.
Might be air in the system...any thoughts?
According to Bob, that is an air pocket that gives the rapid rise in temp, Steam pockets. I called him before I got to that pointe and asked how would I be able to determine if I had an air pocket and he said I'd see what you just described! And no, I haven't connected my fans to the ECU yet. I will after I get my new cable. They sent the wrong one. I was running wired in low speed. My plan is to run it a few miles to get it up to temp then connect to the ECU. Hopefully they will fire right up, at high speed, confirming that the ECU connection is working. Then I will disconnect them, one at a time to determine which is hi/lo.
