QUOTE(rnellums @ Aug 15 2016, 11:52 AM)
QUOTE(914forme @ Aug 15 2016, 09:37 AM)
Electric water pump I am using and Andrew is using is the only pump we have. It actually reduces the flow rate to optimize the engine ability to transfer the heat to the coolant. Yes sometimes things can move to fast or be to big for the combination of systems you have working out.
I see this argument a lot on the forums amd I can't for the life of me make sense of it from a heat transfer perspective, maybe someone can help me understand what im missing.
The radiator is in essence a heat sink with forced convective flow through the fins. For a given radiator set up the heat transferred from the radiator to the air depends on only two things, air velocity (and the associated Reynolds and prandtl numbers), and temperature differential between the radiator and the cooling air.
If you are pumping faster, the temperature drop across the radiator will be less, but the volume of coolant cooled will be greater, and since the radiator temperature will be increased on average, the heat transferred out of the system should be greater. This should result in more efficient cooling, and should continue to improve with increased flow with diminishing returns infinitely.
Can anyone poke any holes in this?
Yeah, that forum argument has always bugged me too; it doesn't make any sense at all. Many people seem to think that increased residence time has some ability to increase energy transferred. That's true in stagnant systems since conduction comes into play, but really has no bearing in convection dominated systems.
"Too fast" flow is not a problem for heat exchange since higher than average coolant temperature across the radiator and higher flow rates always correlate to better heat transfer through increased exergy (available energy for transfer) and higher convection coefficients. The air side is really the limiting portion so there are diminishing returns to increasing water flow rate. Ideally there is some optimal flow rate which trades heat transfer effectiveness for pumping losses to reduce parasitic engine loads.
QUOTE(Andyrew @ Aug 15 2016, 02:25 PM)
My recommendation is that for all 6cyls and below regardless of turbo should run no mechanical water pump unless your build requires you to be below 160deg temp all the time. However most modern engines are efficient up to 225deg this is not a concern.
Coolant temperatures of 160F are really, really, low. Published studies by Caterpillar have shown engine wear at those temperatures to be very high. IMHO it's much better to be operating at the high end of the coolant temperature limit with a higher pressure radiator cap for safety.
