QUOTE(Chris H. @ Jan 29 2015, 11:23 AM)
Stephen,
Interesting...I'm seriously thinking about flipping mine and welding up the hole I cut for the intake. How hard was it? I hate that hole too!
EDIT: and did you flip JUST the top portion of the intake or both sections (it has 2 pieces)?
I flipped the entire thing, you will have to move the alternator! It is pretty easy if you ditch a bunch of stuff, you will have to move the air solenoid.
Looking at it today, I am thinking about doing something a little different. Keeping the bottom half flipped, and moving the return line, and inlet to feed from both sides of the engine. Ever since reading what SDS did for an intake on a 3.3, I have been thinking about making one myself. They did it out of steel, but for some reason, I am thinking about doing lost foam carbon fiber intake. I have seen someone comment on flammability, but then you know the internet, it is full of clowns, who say their cousin's, father's, sister's husband's corvette go up in flames. The forgot he doused it in gas, and diesel fuel, with a touch of kerosene just to give it a nice look. I'll do my own research, I have three ideas right now.
Single TB, main plenum. easiest
ITBs
Or my current favorite, but of course the hardest of all, Stacks looking like MEFI off a 911, going into an 911 style airbox. The filter will be behind the Single TB, which would be mounted behind the air snorkel.
or
Oh and I did have to cut a hole in my rear trunk today, so the first cut is done. Glad I am past that!!!! I had to make clearance for the clutch line. Might elongate it a little and pickup the fork, that would allow me to bring the engine up a little. But then we will see.
I will try and weight the drive train, I can squat 550 pounds right now. Not sure I want to dead lift a subie engine and trans and step on a scale.
In reality I am not sure I have a scale that will tell me. To bad I don't have a set of corner scales. I could give you the total and what the cross weights look like.
Oh I know how I'll do it. But it will have to weight until spring, I'll load the engine in the truck, run down the grain elevator, and hop on the scale, the unload it, and get the weight difference. +-10 pounds okay for you?
Bob, there really ain't to much to see right now,
, except a bare chassis, and a lot of pieces going in, and back out a few hundred times to get things mocked up, welded in, and then removed for paint work. Really kind of boring when you get right down to it. But your more than welcome to stop by. Just PM me hopefully Im in town, crazy work schedule right now also.
I really need to update my thread, just been doing stuff, I'll get to it. Maybe by the time I update it, I will have covered all my mistakes and it will look perfect.
