Tom asked me to add updates as I did work on his gauges for him. We have a few items up our sleeve and this car will have a full array of needles to keep your eyes off of so you can
First item was a new speedo for the car. Subaru uses an electric speed sensor in their MT5's so this car needed a speedo that was electric drive. So here you go, proper VDO 930.641.508.00 And well like most older VDO speedo's Anton thought it was a great idea to lube the gear shaft with a bit of grease. The grease happens to break down the material the gear was built out of.
This is the worse one I have seen in my years of doing these.
Click to view attachmentOdometer Gears LTD to the rescue, meet these guys at Hersey, great group of guys, and I knew at some point I would need at least one of their gears.
Since I did not know the miles on Grey, I asked Tom how he wanted to handle the conversion. He said zero it out, it is a for the most part a brand new car.
Click to view attachmentNext up get the new gear back in and get this thing assembled.
First up, I polished up the shafts, then added a touch of dry graphite bearing treatment to the shaft. Then repolished the shaft to remove excess per directions. Spins smooth now.
Click to view attachmentOverkill
Oh heck yeah it is.
Next up add all the gears and e-clips
Click to view attachmentTest everything and it works
And because of the high definition pictures I see a piece of the old gear in the worm drive on motor, that has been removed.
And it is now together again.
Click to view attachmentThat is all I can do for now. All the needles will be painted at the same time, so they will all match. So I'll bag this one up and move onto the next one.
When I reassemble I will re-dust all the surfaces to get all the last bits out and off the assembly and the faces.
